Volume Box
Volume box is a cuboid shaped volume that can be used to simulate:
- Fog, haze or mist that hides objects behind it. If boxes with fog intersect, denser fog is created.
- Clouds or shaped fog.
- Light shafts from the world light source. For sun beams to fall through windows and other openings, the room should be inside the box.
Volume box with a fog material on the floor
ObjectVolumeBox class
Box Options
On the Volume Box tab of the Parameters window, you can adjust the following parameters of the volume box:
Edit Size | Toggles the editing mode for the volume box node. When enabled, the volume box sides that can be resized are highlighted with the colored rectangles. To change the size of a side, drag the corresponding rectangle. |
Size | Length, width and height of the box (in units) along X, Y and Z axes. |
Last update: 26.04.2018
Была ли эта статья полезной?
