Форум
Документация (2.7.1)
Неподдерживаемая SDK
UNIGINE Future
(Неподдерживаемая SDK)
UNIGINE 2.18.1 (Последняя)
UNIGINE 2.18
UNIGINE 2.17
UNIGINE 2.16.1
UNIGINE 2.16
UNIGINE 2.15.1
UNIGINE 2.15
UNIGINE 2.14.1
UNIGINE 2.14
UNIGINE 2.13
UNIGINE 2.12
UNIGINE 2.11
UNIGINE 2.10
UNIGINE 2.9
UNIGINE 2.8
UNIGINE 2.7.3
UNIGINE 2.7.2
UNIGINE 2.7.1
UNIGINE 2.7
UNIGINE 2.6.1
UNIGINE 2.6
UNIGINE 2.5
UNIGINE 2.4.1
UNIGINE 2.4
UNIGINE 2.3.1
UNIGINE 2.3
UNIGINE 2.2.1
UNIGINE 2.2
UNIGINE 2.1.1
UNIGINE 2.0
UNIGINE 1.0
Показать все версии >>|Скрыть все версии <<
Выберите свой язык
На эти языки документация переведена автоматически, поэтому ее текст может содержать неточности и ошибки.
English
Русский
中文
Français
Deutsch
日本語
한국어
Español
Português
Italiano
Türkçe
Svenska
Suomi
Dansk
Nederlands
Norsk
हिन्दी
Tiếng Việt
Bahasa Indonesia
Polski
Limba Română
Magyar
Cрпски
Slovenčina
Slovenščina
Hrvatski
Český
Bosanski
Македонски
Български
Войти
в API
Не найдено
Введение
What's Inside?
Project Workflow
Migrating to Unigine
Migrating to Unigine From UnrealEngine
Migrating to Unigine From Unity
Programming Quick Start
1. Basic Scene Objects and Coordinate System
2. Logging and Printing Messages to Console
3. Saving and Loading a World
4. Closing the Application
5. Working with Smart Pointers
6. Creating and Deleting Nodes at Runtime
7. Creating and Setting Up a Camera
8. Creating and Setting up Light Sources
9. Creating, Applying and Deleting Materials at Runtime
10. Managing Existing Scene Objects
11. Performing Basic Transformations (Move, Rotate, Scale)
12. Making It in Time
13. Managing Intersections
14. Getting and Managing User Inputs
15. Implementing Game Logic and Using Properties
16. Creating User Interface
System Requirements
The Scene Viewport
Importing 3D Models
Instancing Nodes
Tracker Tool
Global Illumination
Virtual World Structure
World Management
Properties
Hierarchy and Inheritance
Custom Component System
Rendering Sequence
Scattering
PSSM
Temporal Anti-Aliasing
Alpha Blending
Output Modes
Stereo Rendering
NVIDIA 3D Vision Output with App3DVision Plugin
NVIDIA 3D Vision Surround Output with App3DSurround Plugin
Separate Images Output with AppSeparate Plugin
Quad Buffered Stereo Support
Oculus Rift Output with AppOculus Plugin
HTC Vive Output with AppVive Plugin
Multi-Monitor Rendering
Video Wall Output with AppWall Plugin
3 Monitor Output with AppSurround Plugin
Panoramic Rendering
Projections with AppProjection Plugin
Physics
Physical Bodies
Cloth Body
Dummy Body
Fracture Body
Path Body
Ragdoll Body
Rigid Body
Rope Body
Water Body
Shapes
Collision Detection
Joints
Simulation of Physics
Bit Masking
Import System
File System
SDK-браузер
Projects
Licenses
Add-Ons
Kinect2 Add-On
Tutorials Content Add-On
Vegetation Add-On
VRPN Add-On
Layout Customization
Asset Types
Assets and Runtime Files
Creating and Importing Assets
FBX Import Guide
Texture Import Guide
Organizing Assets
Copying Assets From Other Projects
Project Files
Editor Hotkeys
World Settings
Render Settings
Screen
Visibility Distances
Antialiasing
Lights
Shadows
Global Illumination
SSAO
SSGI
Bent Normal
SSS
SSR
SSBevel
Water
Clouds
Vegetation Parameters
Environment
Occlusion Culling
Postprocess
Motion Blur
DOF
Camera Effects
Color
Streaming
Screen-Space Materials
Global Physics Settings
Global Sound Settings
Managing Worlds
Scene Navigation
Creating and Importing Nodes
Selecting and Positioning Nodes
Organizing Nodes
Exporting Nodes
Instancing Nodes
Transformation and Common Parameters
Visual Representation
Properties
Physics
Organizing Materials
Forced Shader Compilation
Organizing Properties
Setting Up Cameras
Using Visual Helpers
System Menu
Creating a Terrain
Creating a Geo-Referenced Terrain
Generating Detail Masks
Generating Vegetation
Generating Spline Objects
Generating Vector Objects
Generating Point Objects
Generating Buildings
Procedural Refinement
Distributed Computing
Making Cutscenes With Camera Motion Control
Basic Operations in Tracker
Creating Type-Specific Tracks
Usage Example
Running Tracks in Application
Capturing Screenshots and Frame Sequences
Adding Variations for a More Realistic Environment
Manual Terrain Modification
Bake Lighting
Switching From the Previous Version of the Editor
UnigineEditor (DEPRECATED)
Overview
Controls
Managing Worlds
Scene Navigation
Setting Up Cameras
Importing Nodes
Organizing Nodes
Exporting Nodes
Rendering Settings
Common
Parameters
TAA
Global Illumination
SSAO
SSGI
Bent Normal
SSS
SSR
Water
Clouds
Environment
Postprocess
Motion Blur
DOF
Camera Effects
Color
Setting Up Physics
Terrain Editor
Terrain Grabber
Video Grabber
Mask Editor
Tools Panel
LUT Generation Tool
Collada Import Plugin
OpenFlight Import Plugin
Importing Large Populated Areas with City Import Plugin
Making Environment Look Realistic with Randomizer Plugin
Exporting Nodes with Node Export Plugin
Baking Meshes into One Mesh with Mesh Combiner Plugin
Interface Plugin
Making Custom Editor Plugins
Инструменты
Plugins for 3D Editors
Plugins for 3ds Max
Plugins for Maya
Performance Profiling Tools
Performance Profiler
Microprofile
ResourceEditor
MeshViewer
NormalCombiner
NormalMapper
AmbientMapper
AlphaMapper
ImageDDS
ImageTTF
USC Interpreter
Tileset File
Archiver
Resource
MeshImport
Upgrade Script
Node
Node Reference
Dummy Node
Layer
Pivot
Trigger
Dummy Object
Static Mesh
Skinned Mesh
Dynamic Mesh
Mesh Cluster
Mesh Clutter
Terrain
Terrain
Terrain Material
Global Terrain
Global Terrain Details
Text Object
Water
Global Water
Water Mesh
Sky
Cloud Layer
Grass
Grass Settings
Tutorial: Adding Grass
Billboards
Stars Generator for Billboards
GUI Objects
GUI Mesh
Particle System
Volumetric Objects
Volume Box
Volume Sphere
Volume Omni
Volume Projected
Fields
Field Spacer
Field Animation
Field Height
Field Shoreline
Field Weather
Physicals
Physical Wind
Physical Force
Physical Noise
Physical Water
Physical Trigger
Projected Decal
Orthographic Decal
Mesh Decal
Light Sources Parameters
Omni Light
Projected Light
World Light
Environment Probe
Geodetic Pivot
World Layer
Sector
Portal
World Trigger
World Cluster
World Clutter
Switcher
Occluders
Occluder
Occluder Mesh
Occluder Terrain
Transforms
Transform Path
Transform Bone
World Expression
Sound Source
Sound Reverb
Navigation Areas
Navigation Sector
Navigation Mesh
Obstacles
Obstacle Box
Obstacle Sphere
Obstacle Capsule
Player Actor
Player Dummy
Player Persecutor
Player Spectator
Programming Overview
Engine Architecture
Execution Sequence
Where to Put Your Code: Update(), Flush() or Render()
Logic System
Typical Architecture of a Unigine-Based Application
Memory Management
Matrix Transformations
Windows Development Environment
Linux Development Environment
Custom Import Plugin
Basic Object Movements
Creating a Car with Suspension Joints
Creating Routes
Dynamic Meshes
Playing Sounds on Collisions
Intersections
Mesh Class
Working with Console
Sharing Data
Adding Scripts to the Project
The Language
Structure of a Program
Data Types
Operators
Control Statements
Selection Statements
if-else
switch-case
Iteration Statements
for
while
do-while
forloop
foreach
foreachkey
Jump Statements
return
goto
break
continue
Other Statements
yield
wait
call()
thread()
Functions
Scope. Namespaces
Object Oriented Programming
Interface Class
Preprocessor Directives
Templates
Language Features
String Global Functions
Script Debugging
UnigineScript Basic Utilities
Unigine::Widgets
Input System
KeyLine System
Dialogs Script
billboards_00
billboards_01
billboards_02
billboards_03
cluster_00
cluster_01
dynamic_00
dynamic_01
dynamic_02
dynamic_03
dynamic_04
dynamic_05
gui_00
gui_01
gui_02
gui_05
gui_06
gui_07
clutter_00
clutter_01
clutter_02
particles_00
particles_01
particles_02
particles_03
particles_04
particles_05
grass_00
grass_01
grass_02
grass_03
mesh_00
mesh_01
mesh_02
app_oculus_00
app_surround_00
app_surround_01
app_wall_00
gpu_monitor_00
renderer_00
sixense_00
ssl_socket_00
ssl_socket_01
Cache Files
Creating C++ Application
Creating C++ Plugin
Integration Samples
Unigine Integration into SDL Application
Library's Namespace
Variable Export
Constant Export
Function Export
Class Export
Data Structure Export
Callbacks
Serialization
App Class
UnigineScript Containers
C++ Plugins
CIGI Protocol Support via CigiClient Plugin
Implementing CIGI Client Logic for a Custom Project
HLA Support via HLAClient Plugin
Implementing HLA Client Logic for a Custom Project
LeapMotion Plugin
Secure SSL Connection via SSLSocket Plugin
Syncker Plugin
Syncker-Specific Options
Configuring Screens and Projections
Renderer Customization via Renderer Plugin
Setting Up Projections with AppEasyBlend Plugin
Creating C# Application
C# API Reference
C# Integration Samples
Application with Direct3D11 via SlimDX Library
Application with Direct3D11 via SharpDX Library
Application with OpenGL via OpenTK Library
C# Usage Examples
Callbacks
Variable Export
Plugin Class
Package Class
Widget Dialog
UUSL Keywords
UUSL GBuffer Structure
UUSL Data Structure
UUSL Parameters
UUSL Textures
UUSL Semantics
UUSL Tessellation
UUSL Compute Shaders
Creating of Custom Shader for Deferred Rendering Pass
Creating of Custom Shader for Forward Rendering Pass
Creating of Custom Shader for Post-Processing
Mesh File Formats
Materials Files
Base Material File Format
User Material File Format
Property File Format
Spline File Format
Startup Command-Line Options
Console
Configuration File
Manual Compilation with SCons
Preprocessor Macros for Rebuilding the Engine
Protecting Your Data with a Password
UI Files
Widgets
Localization
RC Files
Skin Layout
Usage Example
Usage
Performance Analyzer
Container Functions
ArrayMap Classes
ArrayMap Class
ArrayMap::Iterator Class
ArrayVector Class
Map Class
Set Class
Tree Classes
Tree Class
Tree::ConstIterator Class
Tree::Iterator Class
Vector Classes
Vector Class
Vector::ConstIterator Class
Vector::Iterator Class
Async Class
Atomiclock Class
Blob Class
CallbackBase Class
Checksum Class
Compress Class
ConsoleVariableFloat Class
ConsoleVariableInt Class
ConsoleVariableString Class
Expression Class
ExternClass Class
FunctionBase Class
Hash Class
Hasher Class
File Import Classes
Data Structures
Import Class
Importer Class
ImportProcessor Class
ImportScene Class
Image Class
Interpreter Class
Json Class
Log Class
Logic Classes
EditorLogic Class
SystemLogic Class
WorldLogic Class
Component System Classes
ComponentBase Class
ComponentSystem Class
OS Functions
Path Class
Plugin Class
Property Class
Ptr Class
Reflection Class
RegExp Class
Resource Class
Stream Class
String Class
StringArray Class
StringPtr Class
StringStack Class
System Functions
Thread Class
Timer Class
TypeInfo Class
Unigine Namespace Items
Utils Class
Variable Class
Xml Class
Controls Class
ControlsApp Class
ControlsDummy Class
ControlsJoystick Class
ControlsSixAxis
ControlsXPad360 Class
App Class
Config Class
Console Class
Editor Class
Engine Class
EnginePtr Class
engine.system Functions
EnginePlugins Class
Game Class
GameIntersection Class
Memory Class
Profiler Class
Properties Class
Sound Class
Sounds Class
Splash Class
Visualizer Class
World Class
Dir Class
File Class
Filesystem Class
FileSystemAssets Class
File System Functions
Package Class
PackageUng Class
Gui Class
UserInterface Class
Widget Class
WidgetButton Class
WidgetCanvas Class
WidgetCheckBox Class
WidgetComboBox Class
WidgetDialog Class
WidgetDialogColor Class
WidgetDialogFile Class
WidgetDialogImage Class
WidgetDialogMessage Class
WidgetEditLine Class
WidgetEditText Class
WidgetExternBase Class
WidgetExtern Class
WidgetGridBox Class
WidgetGroupBox Class
WidgetHBox Class
WidgetHPaned Class
WidgetIcon Class
WidgetLabel Class
WidgetListBox Class
WidgetManipulator Class
WidgetManipulatorScaler Class
WidgetMenuBar Class
WidgetMenuBox Class
WidgetScroll Class
WidgetScrollBox Class
WidgetSlider Class
WidgetSpacer Class
WidgetSpinBox Class
WidgetSprite Class
WidgetSpriteNode Class
WidgetSpriteShader Class
WidgetSpriteVideo Class
WidgetSpriteViewport Class
WidgetTabBox Class
WidgetTreeBox Class
WidgetVBox Class
WidgetVPaned Class
WidgetWindow Class
Predefined Constants
Bounds-Related Classes
BoundBox Class
BoundFrustum Class
BoundSphere Class
WorldBoundBox Class
WorldBoundFrustum Class
WorldBoundSphere Class
Geometry Class
Math Common Functions
Math 2D Functions
Math Exponential Functions
Math Matrix Functions
Math Random Functions
bvec4 Class
dmat4 Class
dvec2 Class
dvec3 Class
dvec4 Class
half Class
hvec2 Class
hvec3 Class
hvec4 Class
ivec2 Class
ivec3 Class
ivec4 Class
mat2 Class
mat3 Class
mat4 Class
quat Class
vec2 Class
vec3 Class
vec4 Class
Node Class
NodeDummy Class
NodeExtern Class
NodeExternBase Class
NodeLayer Class
NodePivot Class
NodeReference Class
NodeTrigger Class
Decals-Related Classes
Decal Class
DecalMesh Class
DecalOrtho Class
DecalProj Class
Field-Related Classes
Field Class
FieldAnimation Class
FieldHeight Class
FieldShoreline Class
FieldSpacer Class
FieldWeather Class
Geodetics-Related Classes
Ellipsoid Class
Dataset Class
DatasetRasterPosResolver Class
DatasetSpatialReference Class
DatasetCoordinateTransformer Class
GeodeticPivot Class
Lights-Related Classes
BakeLighting Class
Light Class
LightEnvironmentProbe Class
LightVoxelProbe Class
LightOmni Class
LightProj Class
LightWorld Class
LightLensFlare Class
Object Class
ObjectBillboards Class
ObjectCloudLayer Class
ObjectDummy Class
ObjectDynamic Class
ObjectExtern Class
ObjectExternBase Class
ObjectGrass Class
ObjectGui Class
ObjectGuiMesh Class
ObjectIntersection Class
ObjectMeshStatic Class
ObjectMeshCluster Class
ObjectMeshClutter Class
ObjectMeshDynamic Class
ObjectMeshSkinned Class
ObjectParticles Class
ObjectSky Class
ObjectTerrain Class
ObjectTerrainGlobal Class
TerrainGlobalDetail Class
TerrainGlobalLod Class
TerrainGlobalLodHeight Class
TerrainGlobalLods Class
TileSet Class
TileSetFile Class
ObjectText Class
ObjectVolumeBox Class
ObjectVolumeOmni Class
ObjectVolumeProj Class
ObjectVolumeSphere Class
ObjectWaterMesh Class
ObjectWaterGlobal Class
Players-Related Classes
Player Class
PlayerActor Class
PlayerDummy Class
PlayerPersecutor Class
PlayerSpectator Class
Sound Nodes-Related Classes
AmbientSource Class
SoundReverb Class
SoundSource Class
World Nodes-Related Classes
WorldCluster Class
WorldClutter Class
WorldExpression Class
WorldExternBase Class
WorldExtern Class
WorldIntersection Class
WorldIntersectionNormal Class
WorldLayer Class
WorldOccluder Class
WorldOccluderMesh Class
WorldOccluderTerrain Class
WorldPortal Class
WorldSector Class
WorldSplineGraph Class
SplineGraph Class
WorldSwitcher Class
WorldTransformBone Class
WorldTransformPath Class
WorldTrigger Class
Socket Class
Navigation Class
NavigationMesh Class
NavigationSector Class
Obstacle Class
ObstacleBox Class
ObstacleCapsule Class
ObstacleSphere Class
PathRoute Class
PathRouteIntersection Class
Contact Class
Physics Class
PhysicsIntersection Class
Bodies-Related Classes
Body Class
BodyCloth Class
BodyDummy Class
BodyFracture Class
BodyParticles Class
BodyPath Class
BodyRagDoll Class
BodyRigid Class
BodyRope Class
BodyWater Class
Joints-Related Classes
Joint Class
JointBall Class
JointCylindrical Class
JointFixed Class
JointHinge Class
JointParticles Class
JointPath Class
JointPrismatic Class
JointSuspension Class
JointWheel Class
Physical Class
PhysicalForce Class
PhysicalTrigger Class
PhysicalNoise Class
PhysicalWater Class
PhysicalWind Class
Shapes-Related Classes
Shape Class
ShapeBox Class
ShapeCapsule Class
ShapeConvex Class
ShapeCylinder Class
ShapeSphere Class
AppEasyBlendInterface Class
ColladaImport Class
OpenFlightImport Class
engine.grabber Functions
engine.kinect Functions
engine.oculus Functions
engine.projection Functions
engine.surround Functions
engine.vive Functions
engine.wall Functions
CIGI Client interface
IArticulatedPart Class
IComponent Class
IEntity Class
IViewBase Class
IView Class
IViewGroup Class
ICigiHostPacket Class
ICigiArticulatedControl Class
ICigiArticulatedShortControl Class
ICigiAtmosphereControl Class
ICigiCelestialControl Class
ICigiComponentControl Class
ICigiComponentShortControl Class
ICigiEntityControl Class
ICigiEntityClampedControl Class
ICigiEnvironmentControl Class
ICigiEnvironmentRequest Class
ICigiIGControl Class
ICigiMaritimeControl Class
ICigiRateControl Class
ICigiSensorControl Class
ICigiSymbolCircleDef Class
ICigiSymbolClone Class
ICigiSymbolControl Class
ICigiSymbolShortControl Class
ICigiSymbolLineDef Class
ICigiSymbolSurfaceDef Class
ICigiSymbolTextDef Class
ICigiTerrestrialControl Class
ICigiTrackerControl Class
ICigiViewControl Class
ICigiWaveControl Class
ICigiWeatherControl Class
ICigiViewDef Class
ICigiEarthModelDef Class
ICigiSegmentDef Class
ICigiTrajectoryDef Class
ICigiVolumeDef Class
ICigiHatHotRequest Class
ICigiIGPacket Class
ICigiStartOfFrame Class
ICigiAerosolResponse Class
ICigiHatHotResponse Class
ICigiHatHotExtResponse Class
ICigiLosSegmentRequest Class
ICigiLosVectorRequest Class
ICigiLosResponse Class
ICigiLosExtResponse Class
ICigiMaritimeResponse Class
ICigiPositionRequest Class
ICigiPositionResponse Class
ICigiSensorResponse Class
ICigiSensorExtResponse Class
ICigiTerrestrialResponse Class
ICigiWeatherResponse Class
HLA Client Plugin
Interface Plugin
InterfaceWindow Class
Engine Interface Class
LeapMotion Plugin
LeapMotionInterface Class
LeapMotionArm Class
LeapMotionBone Class
LeapMotionFinger Class
LeapMotionHand Class
Syncker Plugin
ManagerInterface Class
SynckerInterface Class
MasterInterface Class
SlaveInterface Class
VRPN Plugin
VrpnAnalogDevice Class
VrpnButtonDevice Class
VrpnTrackerDevice Class
Camera Class
Ffp Class
Material Class
Materials Class
Mesh Class
MeshDynamic Class
Primitives Class
Render Class
RenderEnvironmentPreset Class
Renderer Class
RenderContext Class
RenderState Class
Shader Class
StructuredBuffer Class
Texture Class
TextureRender Class
Viewport Class
3D Models Requirements
Art Assets Conversion
Material Library
billboards_base
billboards_cloud_base
billboards_impostor_base
clouds_base
decal_base
grass_base
grass_impostor_base
gui_base
mesh_base
Physically Based Materials
particles_base
render_composite
sky_base
terrain_base
terrain_global_base
volume_cloud_base
volume_fog_base
volume_light_base
volume_omni_base
volume_proj_base
volume_shaft_base
water_global_base
Postprocess Materials
post_blur_radial
post_filter_rgb2rgbl
post_filter_rgb2yuv
post_filter_sobel
post_filter_wet
post_hblur_2d
post_sensor
post_vblur_2d
post_hblur_mask
post_vblur_mask
post_hblur_cube and post_vblur_cube
Debug Materials
debug_materials
Custom Materials
Adding Morph Targets
Setting Up Object LODs
Adding Impostors to Clutters
Migrating to UNIGINE 2.7.1
API Migration
Console Migration
Содержание
Внимание! Эта версия документация УСТАРЕЛА, поскольку относится к более ранней версии SDK! Пожалуйста,
переключитесь на самую актуальную документацию для последней версии SDK
Внимание! Эта версия документации описывает устаревшую версию SDK, которая больше не поддерживается! Пожалуйста,
обновитесь до последней версии SDK.
Код на
языке
отсутствует для этой страницы, можно выбрать другой язык.
Нет кода на
языке
для этой страницы,
отображается код на
другом
Double
Копировать
Terrain
Artists
UNIGINE 2
The article on the Landscape Tool is now available
here
Last update: 04.06.2018
Была ли эта статья полезной?
Да
Нет
0
из
0
пользователей считают статью полезной
Сообщить о проблеме в этой статье
Вы уже проголосовали
О какой проблеме вы хотели бы сообщить?
Проблема :
Отсутствует информация
Искажение информации
Непонятное или неоднозначное описание
Опечатка или грамматическая ошибка
Примеры кода нерабочие
Не хватает примеров кода
Другое
Подробнее *:
Войти
Email:
Пароль:
Забыли пароль?
Мы используем файлы cookie, чтобы вам было удобнее работать на нашем веб-сайте. Перейдите по
ссылке
для получения более подробной информации.
Got it
