Эта версия документации УСТАРЕЛА! Пожалуйста, переключитесь на последнюю версию.
Playing Sounds on Collisions
The example below demonstrates how to:
  • Create a new sound source.
  • Update settings of the existing sound source.
  • Implement a contact callback that plays a sound at a contact with a physical body.
The sound file used in the example can be found in the <UnigineSDK>/data/samples/sounds/sounds folder. You can also specify any other file, including .mp3.
AppWorldLogic.h:
#ifndef __APP_WORLD_LOGIC_H__
#define __APP_WORLD_LOGIC_H__
#include <UnigineLogic.h>
#include <UnigineStreams.h>
#include <UniginePhysics.h>
#include <UnigineMesh.h>
#include <UnigineSounds.h>
#include <UnigineObjects.h>
#include <UnigineEditor.h>
	AppWorldLogic();
	virtual ~AppWorldLogic();
	virtual int init();
	virtual int update();
	virtual int render();
	virtual int flush();
	virtual int shutdown();
	virtual int destroy();
	// callbacks
	struct ContactArguments
		Unigine::BodyPtr body;
		int num;
		ContactArguments(const Unigine::BodyPtr &body, int num)
			this->body = body;
			this->num = num;
	Unigine::Vector<ContactArguments> callbacks;
	Unigine::Vector<Unigine::SoundSourcePtr> sounds;
	void contact_callback(Unigine::BodyPtr body, int num);
	void contact_callback_handler(const Unigine::BodyPtr &body, int num);
	void create_box(Unigine::Math::Vec3 position);
AppWorldLogic.cpp:
#include "AppWorldLogic.h"
// a callback function that will be run when a contact with a given body emerges
void AppWorldLogic::contact_callback(BodyPtr body, int num)
	callbacks.append(new ContactArguments(body, num));
void AppWorldLogic::contact_callback_handler(const BodyPtr &body, int num)
	if (num >= body->getNumContacts())
		return;
	// get coordinates of the contact point
	Vec3 position = body->getContactPoint(num);
	// get the relative impulse in the contact point
	float impulse = body->getContactImpulse(num);
	// calculate volume of the sound played for the contact
	float volume = impulse * 0.5f - 1.0f;
	// a flag indicating that no sounds have played yet
	bool need_sound = true;
	for (int i = 0; i < sounds.size(); i++)
		if (!sounds[i]->isPlaying())
			need_sound = false;
			// reuse the existing sound source
			sounds[i]->setEnabled(1);
			sounds[i]->setGain(saturate(volume));
			sounds[i]->setWorldTransform(translate(position));
			Sound::get()->renderWorld(1);
			sounds[i]->play();
			break;
	if (need_sound)
		// create a new sound source
		SoundSourcePtr s = SoundSource::create("static_impact_00.wav");
		// specify necessary settings for the sound source
		s->setOcclusion(0);
		s->setMinDistance(10.0f);
		s->setMaxDistance(100.0f);
		s->setGain(saturate(volume));
		s->setWorldTransform(translate(position));
		// play the sound source
		s->play();
		// append the sound to the vector of the playing sounds
		sounds.append(s);
// method creating a box mesh with a physical body
void AppWorldLogic::create_box(Vec3 position)
	mesh->addBoxSurface("box_0", vec3(0.5f));
	ObjectMeshStaticPtr object_mesh = ObjectMeshStatic::create(mesh);
	object_mesh->release();
	Editor::get()->addNode(object_mesh->getNode());
	object_mesh->setMaterial("mesh_base", "*");
	object_mesh->setProperty("surface_base", "*");
	object_mesh->setWorldTransform(translate(position));
	BodyRigidPtr body = BodyRigid::create(object_mesh->getObject());
	ShapeBox::create(body->getBody(), vec3(0.5f));
	// set a callback function that is run when a contact with the box occurs
	body->setContactCallback(MakeCallback(this, &AppWorldLogic::contact_callback));
int AppWorldLogic::init() {
	// create box meshes
	for (int i = -5; i <= 5; i++) {
		AppWorldLogic::create_box(Vec3(0.0f, i * 2.0f, 8.0f + i * 1.0f));
	// create another box mesh
	AppWorldLogic::create_box(Vec3(5.0f, 10.0f, 50.0f));
	sounds.clear();
	callbacks.clear();
int AppWorldLogic::update() {
	if (callbacks.size() > 0)
		for (int i = 0; i lt; callbacks.size(); i++)
			contact_callback_handler(callbacks[i]->body, callbacks[i]->num);
			delete callbacks[i];
		callbacks.clear();
int AppWorldLogic::render() {
int AppWorldLogic::flush() {
		sounds[i].clear();
	sounds.clear();
int AppWorldLogic::destroy() {
	UNIGINE_UNUSED(stream);
Last update: 04.06.2018
