Unigine::ObjectTerrainGlobal Class
Header:#include <UnigineObjects.h>
Inherits:Object
This class is used to create a global terrain object representing a certain fragment of Earth's surface on the basis of available GIS data (elevation and imagery). The global terrain is rendered using pre-generated tilesets which represent LODs for different data layers (heights, albedo and normals).
Members
static ObjectTerrainGlobalPtr create()
Constructor. Creates a new empty global terrain object with default properties.
static Ptr<ObjectTerrainGlobal> cast(const Ptr<Node> & node)
Casts an ObjectTerrainGlobal out of the Node instance.
Arguments
  • const Ptr<Node> & node - Pointer to Node.
Return value
Pointer to ObjectTerrainGlobal.
static Ptr<ObjectTerrainGlobal> cast(const Ptr<Object> & base)
Casts an ObjectTerrainGlobal out of the Object instance.
Arguments
  • const Ptr<Object> & base - Pointer to Object.
Return value
void setAlbedoLodClearDistance(int num, float distance)
Sets the clear distance of a given albedo LOD. Starting from this distance the tiles of the LOD are removed from memory.
Arguments
  • int num - Albedo LOD number.
  • float distance - Clear distance, in units.
float getAlbedoLodClearDistance(int num)
Returns the clear distance of a given albedo LOD. Starting from this distance the tiles of the LOD are removed from memory.
Arguments
Return value
void setAlbedoLodEnabled(int num, int enabled)
Enables or disables a given albedo LOD.
Arguments
  • int enabled - 1 to enable the LOD, 0 to disable it.
int getAlbedoLodEnabled(int num)
Returns a value indicating if a given albedo LOD is enabled.
Arguments
Return value
1 if a given albedo LOD is enabled; otherwise, 0.
void setAlbedoLodLoadDistance(int num, float distance)
Sets the load distance for a given albedo LOD. Starting from this distance the tiles of the LOD are loaded into memory.
Arguments
  • float distance - Load distance, in units.
float getAlbedoLodLoadDistance(int num)
Returns the load distance for a given albedo LOD. Starting from this distance the tiles of the LOD are loaded into memory.
Arguments
Return value
void setAlbedoLodPath(int num, const char * path)
Sets the path to the folder where a given albedo LOD is stored.
Arguments
  • const char * path - Path to the folder where a given albedo LOD is stored.
const char * getAlbedoLodPath(int num)
Returns the path to the folder where a given albedo LOD is stored.
Arguments
Return value
float getAlbedoLodTileDensity(int num)
Returns the density of a tile of a given albedo LOD.
Arguments
Return value
Density of a height LOD tile, in meters per pixel.
void setAlbedoLodViewportMask(int num, int mask)
Sets the viewport mask for a given albedo LOD.
Arguments
  • int mask - Viewport mask.
int getAlbedoLodViewportMask(int num)
Returns the viewport mask for a given albedo LOD.
Arguments
Return value
Viewport mask.
void setAlbedoLodVisibleDistance(int num, float distance)
Sets the visible distance of a given albedo LOD. Starting from this distance the tiles of the LOD become visible.
Arguments
  • float distance - Visible distance, in units.
float getAlbedoLodVisibleDistance(int num)
Returns the visible distance of a given albedo LOD. Starting from this distance the tiles of the LOD become visible.
Arguments
Return value
int getAlbedoNumLods()
Returns the total number of albedo LODs.
Return value
Total number of albedo LODs.
String getAlbedoVideoMemoryUsage()
Returns information about the total video memory usage for all albedo LODs.
Return value
Total video memory usage for all albedo LODs.
void setHeightLodClearDistance(int num, float distance)
Returns the clear distance of a given height LOD. Starting from this distance the tiles of the LOD are removed from memory.
Arguments
  • int num - Height LOD number.
float getHeightLodClearDistance(int num)
Arguments
Return value
void setHeightLodCollision(int num, int enabled)
Enables or disables collision detection for a given height LOD.
Arguments
  • int enabled - 1 to enable collision detection, 0 to disable it.
int getHeightLodCollision(int num)
Returns a value indicating if collision detection for a given height LOD is enabled.
Arguments
Return value
1 if collision detection for a given LOD is enabled; otherwise, 0.
void setHeightLodCollisionMask(int num, int mask)
Sets the collision mask for a given height LOD.
Arguments
  • int mask - Collision mask.
int getHeightLodCollisionMask(int num)
Returns the collision mask for a given height LOD.
Arguments
Return value
Collision mask.
void setHeightLodEnabled(int num, int enabled)
Enables of disables a given height LOD.
Arguments
int getHeightLodEnabled(int num)
Returns a value indicating if a given height LOD is enabled.
Arguments
Return value
1 if a given height LOD is enabled; otherwise, 0.
void setHeightLodIntersection(int num, int enabled)
Enables or disables intersection detection for a given height LOD.
Arguments
  • int enabled - 1 to enable intersection detection, 0 to disable it.
int getHeightLodIntersection(int num)
Returns a value indicating if intersection detection for a given height LOD is enabled.
Arguments
Return value
1 if intersection detection for a given LOD is enabled; otherwise, 0.
void setHeightLodIntersectionMask(int num, int mask)
Sets the intersection mask for a given height LOD.
Arguments
  • int mask - Intersection mask.
int getHeightLodIntersectionMask(int num)
Arguments
Return value
Intersection mask.
void setHeightLodLoadDistance(int num, float distance)
Sets the load distance for a given height LOD. Starting from this distance the tiles of the LOD are loaded into memory.
Arguments
float getHeightLodLoadDistance(int num)
Returns the load distance for a given height LOD. Starting from this distance the tiles of the LOD are loaded into memory.
Arguments
Return value
void setHeightLodPath(int num, const char * path)
Sets the path to the folder where a given height LOD is stored.
Arguments
  • const char * path - Path to the folder where a given height LOD is stored.
const char * getHeightLodPath(int num)
Returns the path to the folder where a given height LOD is stored.
Arguments
Return value
float getHeightLodTileDensity(int num)
Returns the density of a tile of a given height LOD.
Arguments
Return value
void setHeightLodViewportMask(int num, int mask)
Sets the viewport mask for a given height LOD.
Arguments
int getHeightLodViewportMask(int num)
Returns the viewport mask for a given height LOD.
Arguments
Return value
Veiwport mask.
void setHeightLodVisibleDistance(int num, float distance)
Sets the visible distance of a given height LOD. Starting from this distance the tiles of the LOD become visible.
Arguments
float getHeightLodVisibleDistance(int num)
Returns the visible distance of a given height LOD. Starting from this distance the tiles of the LOD become visible.
Arguments
Return value
int getHeightNumLods()
Returns the total number of height LODs.
Return value
Total number of height LODs.
String getHeightVideoMemoryUsage()
Returns information about the total video memory usage for all height LODs.
Return value
Total video memory usage for all height LODs.
void setNormalLodClearDistance(int num, float distance)
Sets the clear distance of a given normal LOD. Starting from this distance the tiles of the LOD are removed from memory.
Arguments
  • int num - Normal LOD number.
float getNormalLodClearDistance(int num)
Returns the clear distance of a given normal LOD. Starting from this distance the tiles of the LOD are removed from memory.
Arguments
Return value
void setNormalLodEnabled(int num, int enabled)
Enables or disables a given normal LOD.
Arguments
int getNormalLodEnabled(int num)
Returns a value indicating if a given normal LOD is enabled.
Arguments
Return value
1 if a given normal LOD is enabled; otherwise, 0.
void setNormalLodLoadDistance(int num, float distance)
Sets the load distance for a given normal LOD. Starting from this distance the tiles of the LOD are loaded into memory.
Arguments
float getNormalLodLoadDistance(int num)
Returns the load distance for a given normal LOD. Starting from this distance the tiles of the LOD are loaded into memory.
Arguments
Return value
void setNormalLodPath(int num, const char * path)
Sets the path to the folder where a given normal LOD is stored.
Arguments
  • const char * path - Path to the folder where a given normal LOD is stored.
const char * getNormalLodPath(int num)
Returns the path to a given normal LOD.
Arguments
Return value
float getNormalLodTileDensity(int num)
Returns the density of a tile of a given normal LOD.
Arguments
Return value
Density of a normal LOD tile, in meters per pixel.
void setNormalLodViewportMask(int num, int mask)
Sets the viewport mask for a given normal LOD.
Arguments
int getNormalLodViewportMask(int num)
Returns the viewport mask for a given normal LOD.
Arguments
Return value
Viewport mask.
void setNormalLodVisibleDistance(int num, float distance)
Sets the visible distance of a given normal LOD. Starting from this distance the tiles of the LOD become visible.
Arguments
float getNormalLodVisibleDistance(int num)
Returns the visible distance of a given normal LOD. Starting from this distance the tiles of the LOD become visible.
Arguments
Return value
int getNormalNumLods()
Returns the total number of normal LODs.
Return value
Total number of normal LODs.
String getNormalVideoMemoryUsage()
Returns information about the total video memory usage for all normal LODs.
Return value
Total video memory usage for all normal LODs.
int addAlbedoLod()
Adds a new albedo LOD.
Return value
1 if a new albedo LOD was added successfully; otherwise, 0.
int addHeightLod()
Adds a new height LOD.
Return value
1 if a new height LOD was added successfully; otherwise, 0.
int addNormalLod()
Adds a new normal LOD.
Return value
1 if a new normal LOD was added successfully; otherwise, 0.
void clear()
Removes all current terrain data from memory.
int fetchAlbedoes(const BoundSphere & bs, const BoundBox & bb, int force = 0)
Loads the data of all albedo LODs for the tiles within a given bounding box and a bounding sphere.
Arguments
  • const BoundSphere & bs - Bounding sphere.
  • const BoundBox & bb - Bounding sphere.
  • int force - Force flag. Use 1 to load files in any case; otherwise, 0. The default value is 0.
Return value
1 if the data of all albedo LODs was fetched successfully; otherwise, 0.
int fetchHeights(const BoundSphere & bs, const BoundBox & bb, int force = 0)
Loads the data of all height LODs for the tiles within a given bounding box and a bounding sphere.
Arguments
  • const BoundBox & bb - Bounding box.
Return value
1 if the data of all height LODs was fetched successfully; otherwise, 0.
int fetchNormals(const BoundSphere & bs, const BoundBox & bb, int force = 0)
Loads the data of all normal LODs for the tiles within a given bounding box and a bounding sphere.
Arguments
Return value
1 if the data of all normal LODs was fetched successfully; otherwise, 0.
int fetchTopologyData(double x, double y, Math::Vec3 & ret_point, Math::vec3 & ret_normal, Math::vec3 & ret_up, int force = 0)
Returns topology data for a given terrain point
Arguments
  • double x - X coordinate of the point.
  • double y - Y coordinate of the point.
  • Math::Vec3 & ret_point - World coordinates of the point.
  • Math::vec3 & ret_normal - Normal coordinates.
  • Math::vec3 & ret_up - "Up" vector coordinates.
Return value
1 if the topology data was fetched successfully; otherwise, 0.
void removeAlbedoLod(int num)
Removes a given albedo LOD.
Arguments
void removeHeightLod(int num)
Arguments
void removeNormalLod(int num)
Removes a given normal LOD.
Arguments
static int type()
Returns the type of the object.
Return value
Object Terrain Global type identifier
Last update: 03.07.2017
