In this example, you will learn how to stop and start the playback of all sounds on a specific channel.
Creating Sounds#
In order to control sounds in the scene, we should have them. Let's review how to add sounds.
The Sound Source object can be created in UnigineEditor as a node (let's assume we did this way in our example), while Ambient Source doesn't have any specific location and is created via code only.
In the init() method, we create the ambient source and configure it as required.
int AppWorldLogic::init()
	AmbientSourcePtr ambient_0 = AmbientSource::create("sound0.mp3");
	ambient_0->setSourceMask(1);
	ambient_0->setLoop(1);
	ambient_0->play();
Having all these sources at hand, we can fine-tune their behavior.
Getting Sounds#
Now we need to get sounds to control them. We'll get Sound Sources by using the method World::getNodesByType() and add them to the vector storing all sound source nodes:
void getAllSoundSources(Vector<SoundSourcePtr> &out_sounds)
	Vector<NodePtr> nodes;
	World::getNodesByType(Node::SOUND_SOURCE, nodes);
	out_sounds.clear();
	for (auto &n : nodes)
		out_sounds.append(checked_ptr_cast<SoundSource>(n));
We'll also declare a vector storing all ambient sounds:
	Unigine::Vector<Unigine::AmbientSourcePtr> ambient_sounds;
And add one more sound setting in the init() method that will add the ambient sound to the vector:
ambient_sounds.append(ambient_0);
Controlling the Playback#
We can control the playback via the SoundSource and the AmbientSource class methods play(), stop(), and setTime(). The general approach is to get all sound sources with the mask of the required channel enabled and then pause them using stop(). This method doesn't reset the playback time, therefore the play() method will resume the sound playback from the moment it has been paused.
First, we create a method that plays sounds that have the corresponding sound channel enabled.
void playSourceChannel(int number, const Vector<SoundSourcePtr> &sounds)
	for (auto &s : sounds)
		if (s->getSourceMask() & (1 << number))
			s->play();
Then we create a method that will play both Sound Sources and Ambient Sources on the specified channel at the same time:
void playSourceChannel(int number, const Vector<SoundSourcePtr> &sources, const Vector<AmbientSourcePtr> &ambients)
	playSourceChannel(number, sources);
	for (auto &a : ambients)
		if (a->getSourceMask() & (1 << number))
			a->play();
Stopping the sound playback uses the same approach.
If a sound source plays on several channels, disabling it means that it will be disabled on all channels.
void stopSourceChannel(int number, const Vector<SoundSourcePtr> &sounds)
			s->stop();
void stopSourceChannel(int number, const Vector<SoundSourcePtr> &sources, const Vector<AmbientSourcePtr> &ambients)
	stopSourceChannel(number, sources);
			a->stop();
The only thing left is to bind methods and buttons:
int AppWorldLogic::update()
	if (Input::isKeyDown(Input::KEY_P))
		Vector<SoundSourcePtr> sources;
		getAllSoundSources(sources);
		playSourceChannel(0, sources, ambient_sounds);
	if (Input::isKeyDown(Input::KEY_S))
		stopSourceChannel(0, sources, ambient_sounds);
Code Sample#
Here's a complete code:
#include <UnigineLogic.h>
#include <UnigineVector.h>
#include <UnigineSounds.h>
	AppWorldLogic() {}
	virtual ~AppWorldLogic() {}
	int init() override;
	int update() override;
#include "AppWorldLogic.h"
#include <UnigineWorld.h>
#include <UnigineInput.h>
	out_sounds.clear();
			s->play();
			a->play();
			s->stop();
			a->stop();
	ambient_0->play();
	AmbientSourcePtr ambient_1 = AmbientSource::create("sound1.mp3");
	ambient_1->setSourceMask(1);
	ambient_1->setLoop(1);
	ambient_1->play();
	ambient_sounds.append(ambient_1);
Last update: 10.07.2025
