cluster_00
This article describes the data/samples/objects/cluster_00.cpp sample.
The cluster_00 sample demonstrates how to:
- Create a cluster of identical meshes by using the ObjectMeshCluster
- Set a material and property for surfaces of the meshes
- Article on Mesh Cluster
- Functions of the ObjectMeshCluster class
Была ли эта статья полезной?
