ashwin.sudhir Posted November 3, 2011 Share Posted November 3, 2011 Hi, We've been trying to create ragdolls manually and setting up joints becomes pretty important. I could not find any doc/tutorial on doing this and the Joints tab in a ragdoll is not really self explanatory. Where can I find help on this? Thanks, Ashwin. Link to comment
manguste Posted November 9, 2011 Share Posted November 9, 2011 I will add docs on joints (most probably in a month), but if you create a ragdoll it is more convenient to use data/samples/physics/common/ragdoll.h script. (Attached one is a bit modified, it will be available in the next update). Ragdolls created through this script are more easily controllable. You just need to customize it and you can create as many ragdolls as you need with required precision. ragdoll.h Link to comment
