Errors when using Blend2d.cs
Go to solution Solved by fox,
Im using the Blend2d.cs sample script from the ObjectMeshSkinned API documentation, https://developer.unigine.com/en/docs/latest/api/library/objects/class.objectmeshskinned?subnavView=brief&subnavSort=name.  The script works but there were a few things I needed to change first because the script has some syntax errors when running under version 2.20.
int id = meshSkinned.AddAnimation(animations[i].asset.Path);
I had to comment out this line because this method no longer exists
meshSkinned.SetAnimation(meshSkinned.NumLayers - 1, id);
I had to comment out this line because this method no longer exists and replace it with:
meshSkinned.SetLayerAnimationFilePath(meshSkinned.NumLayers - 1, animations[i].asset.Path);
int numFrames = meshSkinned.GetNumAnimationFrames(id);
int numFrames = meshSkinned.GetLayerNumFrames(meshSkinned.NumLayers - 1);
meshSkinned.setLayerFrame(i, frame);
This method exists but S in setLayer needs to be capitalized:  meshSkinned.SetLayerFrame(i, frame);
After making these changes the script works fine under 2.20.  And my character has blend space animations.  :)
Edited by webnetweaver
  • Solution
Hi @webnetweaver!
Seems like the update has skipped this snippet. We'll  have it fixed ASAP!
Thanks for pointing out!
