perfectsummer Posted August 5, 2025 Posted August 5, 2025 I have tried many times and it was 100% possible to reproduce. The size of my FBX file is 1G-3G. When I imported it, the progress bar would always be 0, and the progress bar would freeze after I restarted the editor. The reason is that the imported FBX file was normal when I deleted it
silent Posted August 6, 2025 Posted August 6, 2025 perfectsummer In version 2.19, did the same FBX file import correctly? We routinely test FBX imports before each release, and our files ranging from 1–3 GB are typically imported without issues. If possible, could you kindly send me the file via private message for further validation? Thank you! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
perfectsummer Posted August 6, 2025 Author Posted August 6, 2025 11 hours ago, silent said: 完美夏日 在 2.19 版本中,同一个 FBX 文件能正确导入吗?我们每次发布之前都会定期测试 FBX 导入,1 到 3 GB 的文件通常都能顺利导入。 如果可以的话,您能否通过私人消息将文件发送给我以供进一步验证? 谢谢你! I did import an FBX file of similar size in version 2.19 and there was no problem. I'll check later how to send my FBX file to you 1
