Armikron Posted January 28, 2023 Share Posted January 28, 2023 Unigine 2.16.1.0 Community (DX11) Windows 10 GT72 2QE Dominator Pro, i7-4710HQ, 16 GB, GeForce GTX 980M 8 GB - Both videos were recorded using 'High' rendering preset, default C# scene. On stutter video, while moving with WASD keys and moving mouse left and right I get very stuttery/jittery image. I don't think it has to do with rendering, but default FPS Controller. But maybe it is, I don't know. At least I don't get anything like that when orbiting the scene in editor viewport. On another video player gets stuck sometimes. I press 'W' the entire time, even when looking in the opposite direction of stairs. I know anyone seriously using the engine will make his own FPS Controller, but it just gives a bad first impression when trying the engine. unigine_fps_controller_physics_stuck.mkv unigine_fps_controller_stutter.mkv Link to comment
vvvaseckiy Posted January 30, 2023 Share Posted January 30, 2023 Hello Armikron, Thank you for your feedback, we successfully reproduced the issue with sticking to stairs and we'll improve fps controller behavior for this case in future releases. Regarding the stutters in camera movement, we were unable to reproduce this issue so there might be some additional conditions that cause this problem, could you please enable performance profiler ("show_profiler 2" in console) and check if there's any spikes on profiler chart, just to make sure it has nothing to do with rendering. Also please check what your average FPS in scene("show_fps 2" in console) Link to comment
Armikron Posted January 31, 2023 Author Share Posted January 31, 2023 (edited) Hello. I recorded a new video with console commands. Sorry for huge size, I just can't get good quality out of OBS. I want to add that I experience this in both Float and Double made projects. I see a lot of spikes in the video, so it's rendering related? Strange that I don't notice it in editor. unigine_fps_controller_stutter_2.mkv Edited January 31, 2023 by Armikron Link to comment
vvvaseckiy Posted February 2, 2023 Share Posted February 2, 2023 Indeed this uneven frametime can cause visual stutter, unfortunately we can't determine from video what exactly causes this spikes on charts, could you please create and attach a microprofile dump, so we could investigate further. Link to comment
Armikron Posted February 2, 2023 Author Share Posted February 2, 2023 This was made with default microprofile settings and 'high' rendering preset. Let me know if something more needs to be done and/or lower rendering preset needs to be tried. unigine_high_preset_microprofile_dump.zip Link to comment
vvvaseckiy Posted February 7, 2023 Share Posted February 7, 2023 We've tried to reproduce these spikes on same series desktop GTX 980, but unfortunately no success, also from microprofile dump it doesn't looks like performance issue in some specific object\effect. Does these spikes appear only on high render preset, or it also happens on lower ones? Also similar spikes appeared in previous releases, then they've been caused by force enabled vsync in nvidia control panel. The issue was fixed for 2.16.1, but maybe some specific hardware configuration still can be affected by this, could you please check graphics driver version and state of vsync setting in nvidia control panel? Link to comment
Armikron Posted February 8, 2023 Author Share Posted February 8, 2023 Looks like it was a problem on my end. I updated to latest available drivers (528.24) and problem mostly gone away. My V-Sync is set to application preference as before. Still some jitter, especially on 'high' preset, but not nearly as bad. unigine-updated-drivers-high.mkv unigine-updated-drivers-low.mkv Link to comment
vvvaseckiy Posted February 13, 2023 Share Posted February 13, 2023 From the latest videos it seems that there's no spikes in rendering profiler so visually it should be better, still some jittering can be experienced cause of unstable FPS on high preset. You can try to smooth fps by using render_max_fps or enabling vsync. Link to comment
Armikron Posted February 16, 2023 Author Share Posted February 16, 2023 Two tests. One is using High preset, VSync, Max Fps set to 30, FPS controller's mouse sensitivity is set to 1.0. Middle of the video I set render_max_fps command (it's not the same as max fps option in Screen settings?) Second all same, but 60 Fps this time. Still some jitters occur sometimes. unigine_vsync_max30_high_sens1.0.mkv unigine_vsync_max60_high_sens1.0.mkv Link to comment
