Clouds white outline
I noticed that I get white outlines on my objects if I am using an CloudLayer and change the render presets.
Render preset -> Render -> Clouds -> Quality -> Preset, for example high. If I change the preset to Custom it seems that I will get an white outline on everything which is above the horizon.
You can see this effect very strong if you use very dark clouds and set the Interleaved Rendering to 2x2. It will get very noticeable if you move the camera.
The effect will get even stronger if you change the Downsampling Rendering.
Does anybody know what is causing this?
And why can you only observe this behaviour by switching the Preset to Custom?
Am I missing something at the Downsampling or Interleaved Rendering part? Does it effect any other settings?
As far as I understand it I don´t see any reason why this should happen.
Just want to understand the behaviour and if it is intended or not.
Thanks and kind regards
ShadowZelda
The whole thing of custom preset as you can adjust all the settings manually and find a good balance between visuals and performance.
If you can't identify the source of this behavior, could you please send us a minimal upackage with your current cloud layers setup and daytime and we can help you to identify the root cause.
