[SOLVED] CIGI view type can't find material
With a fresh 2.15.1 new IG project, when sending a CIGI view definition with view type set to a valid value defined in ig_config.xml, I always get a warning:
View::setViewType cant find material post_sensor_heat
But the post process material does exists, I can set it in the post process in the editor if needed. I could have sweared that this worked in the past, but even with a fresh new IG project it doesn't work. So what am I missing here?
Hi!
this is our mistake, we forgot to change ig_template.xml from template
please change block <view_types> in your config
	<view_types>
		<view_type type="1" post_materials="Unigine::post_sensor_heat"/>
		<view_type type="2" post_materials="Unigine::post_sensor_green"/>
		<view_type type="3" post_materials="Unigine::post_sensor_white"/>
		<view_type type="4" post_materials="Unigine::post_sensor_red"/>
		<view_type type="5" post_materials="Unigine::post_sensor_white,Unigine::post_sensor_heat"/>
	</view_types>
  • silent changed the title to [SOLVED] CIGI view type can't find material
