How do I add a callback event
As shown in the figure above,I add callback for my button in xml ui file.But How do I add a callback event in C#?
It would be wrong to write it this way.
Edited by hongguang.li
I check the following sample from C#: <UnigineSDK>/source/csharp/samples/Api/Widgets/UserInterface
Is that the only way?As shown in the figure below
Is that still necessary? As shown in the figure below
7 hours ago, silent said:
hongguang.li
You can check the following sample from C#: <UnigineSDK>/source/csharp/samples/Api/Widgets/UserInterface that shows how to parse .ui files and add callbacks (based on MenuBox and EditText widgets).
