dongju.jeong Posted June 13, 2022 Share Posted June 13, 2022 Instead of configuring multiple computer systems and using the syncker feature, is it possible to install multiple graphics cards on one computer and connect multiple monitors to implement a synchronized screen using appProjection+ appWall? (IG project) is there an advantage? Link to comment
silent Posted June 14, 2022 Share Posted June 14, 2022 dongju.jeong You can indeed run multiple engine instances on a single PC, but you should have a very high-end parts for that and balance the CPU load manually so each engine instance will run on a specific CPU cores only. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
