Pierre_Bultingaire Posted May 3, 2022 Share Posted May 3, 2022 Hi, I want to create a storm for my Unigine project (currently using 2.15.1), I used the two types of lightnings provided by the weather samples add-on but to make my storm more realistic I wanted to add more flashes when there is a lightning. In order to do that, I wanted to spawn a bright LighOmni or LightProj for a very short time to flash my CloudLayer but the light doesn't affect the cloud, it stays dark (it affects well my ground when the intensity and distance are really high) Is it possible to do that flash effect with this type of light ? Or change something in the render sequence ? Regards, Pierre Link to comment
silent Posted May 4, 2022 Share Posted May 4, 2022 Hi Pierre, Currently clouds supports light receiving only from WorldLight source. No Omni / Proj sources can be used for that. We do have plans for adding more light receiving sources, but it may take some time due to overall complexity of the clouds object. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
Pierre_Bultingaire Posted May 4, 2022 Author Share Posted May 4, 2022 Hi Silent, Thanks for your answer, I'll try to do a different way then. Regards, Pierre Link to comment
