DIS Entity Marking ?
Should have been more specific: I'm looking for API function or code sample to access the DIS entity marking, for both 2.13 and 2.15.1 (in case the api changed).
I couldn't find it in the doc.
OK, so first I'd suggest to add Marking support in a future version.
Second, I need to access it for a current project, so, how can I intercept the Entity PDU and then match it to an existing IG entity* ?
For future reference, here is the code I used:
Map<int, String> entitiesMarking;
int SystemLogic::init()
	// Note: this code is here because Unigine does not give acces to Entity Marking
	// To be removed when Unigine API is updated...
	if (auto dis = IG::DIS::Connector::get())
		dis->setCallbackOnRecvPacket( // 2.13; for 2.15 use addReceivePacketCallback
            KDIS::DATA_TYPE::ENUMS::Entity_State_PDU_Type,
            MakeCallback(this, &SystemLogic::on_receive_Entity_State_PDU)
void SystemLogic::on_receive_Entity_State_PDU(KDIS::PDU::Header* packet)
	KDIS::PDU::Entity_State_PDU* es = static_cast<KDIS::PDU::Entity_State_PDU*>(packet);
	entitiesMarking[es->GetEntityIdentifier().GetEntityID()] = es->GetEntityMarking().GetEntityMarkingString().c_str();
Only problem now is you deliver a kdis.dll but not the kdis.lib! (so I have to recompile KDIS in my project, which is a risk in case the lib is not exactly the same as you used for the dll generation, for example if you have patched it).
Edited by Amerio.Stephane
