apply wind to the water surface
Does the surface of global water or mesh water change when wind is generated using weather control or atmosphere control?
If it is not applied automatically, can I make a change in the surface of the water with the physical wind?
If physical wind is also impossible, suppose I control the parameters of the water myself.
A way to know if there is water in the range when creating a region wind in weather control?
Or, on the contrary, how to know if there is wind on the surface of the water?
Edited by dongju.jeong
Hello!
Now there is a small problem with the influence of wind on water - a smooth change in wind direction is not available. therefore, we temporarily disabled the effect of global wind on water in IG. (we are working on it, but there is no general solution yet)
however, using the CigiWaveControl package (or via the API) you can force change the direction of the waves.
or you can also manage water directly through api ObjectWaterGlobal
setWindDirectionAngle
setWindAffect
thanks
