Lales.Charles Posted February 2, 2022 Share Posted February 2, 2022 Hi, Attached an fbx generating some errors during import. Test_model_2018_low_game.fbx It seems there is an issue with texture.. but what exactly is going wrong? [...]/shared_AH_test/Test_model_2018_low_game.fbx (0B): import started... ERROR: Importer::importTexture: can't import texture "Test_model_2018_game_low_Diffuse.png" in "asset://[...]/data/shared_AH_test/Test_model_2018_low_game.fbx". ERROR: Importer::importTexture: can't import texture "Test_model_2018_game_low_AO.png" in "asset://[...]/data/shared_AH_test/Test_model_2018_low_game.fbx". ERROR: Importer::importTexture: can't import texture "Test_model_2018_game_low_Specular.png" in "asset://[...]/data/shared_AH_test/Test_model_2018_low_game.fbx". ERROR: Importer::importTexture: can't import texture "Test_model_2018_game_low_Glossiness.png" in "asset://[...]/data/shared_AH_test/Test_model_2018_low_game.fbx". ERROR: Importer::importTexture: can't import texture "Test_model_2018_game_low_Normal.png" in "asset://[...]/data/shared_AH_test/Test_model_2018_low_game.fbx". ERROR: Importer::importTexture: can't import texture "Test_model_2018_game_low_Reflection.png" in "asset://[...]/data/shared_AH_test/Test_model_2018_low_game.fbx". [...]/data/shared_AH_test/Test_model_2018_low_game.fbx: import finished in 5.316228 seconds Do you reproduce? Would you see smthg I'm doing wrong? Regards, Charles Link to comment
romain.janil Posted February 2, 2022 Share Posted February 2, 2022 Hi, silly question but are textures files located in an "existing" relative or absolute path as stored in the .fbx? Otherwise importer probably just doesn't find them this file doesn't have embedded texture assets). Link to comment
Lales.Charles Posted February 2, 2022 Author Share Posted February 2, 2022 Hi, Now that you point it out yes you're maybe right... This asset is demo one of Hum3D platform, and they provided textures in //. So the fbx itself could be maybe better prepared.. or? On Unigine side, simply err msg more explicit "can't import texture" -> "texture not found" or "texture unknown format" or.. Regards, Charles Link to comment
silent Posted February 2, 2022 Share Posted February 2, 2022 Hi Charles, If you have any doubts if the FBX is valid, you can use any other 3rd party FBX viewer and see how model is displayed here. For example, you can use FBX Review directly from Autodesk website: https://apps.autodesk.com/MAYA/en/Detail/Index?id=6979630331069053932&appLang=en&os=Win64 Here's the results: Probably the model itself is borked (wrong texture paths written into FBX). Thanks! 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
Lales.Charles Posted February 3, 2022 Author Share Posted February 3, 2022 Thanks for FBX viewer suggestion ;-) Link to comment
