[SOLVED] How can I control collision?? (node)
I want to access the node and control the collision with the code.
How can i access collision in node??
I want to implement the function of Grabbing nodes.
Regards,
shchoe
I want grab node, use hand tracking
I'm curious about surface collision of the object
ex) mesh collider
I'm looking for a way to access the surface collision with the code.
Thank you
Hello.
You can get information about contacts using the ShapeContact class. For example, let's create interactive objects using ObjectMeshStatic. Add a rigid body and one shape to each of them. Objects will be grab at close range, so sphere intersecton will be used to check. We will only get contacts for nearby objects and then check if the mesh is in collision.
void getObjContacts(const ObjectPtr &obj, float radius, Vector<ShapeContactPtr> &all_contacts)
	all_contacts.clear();
	WorldBoundSphere bs(obj->getWorldPosition(), radius);
	Vector<NodePtr> nodes;
	World::getIntersection(bs, Node::OBJECT_MESH_STATIC, nodes);
	for (int i = 0; i < nodes.size(); i++)
		BodyPtr body = nodes[i]->getObjectBody();
		if (!body || body->getNumShapes() == 0)
			continue;
		ShapePtr shape = body->getShape(0);
		Vector<ShapeContactPtr> contacts;
		shape->getCollision(contacts);
		for (int j = 0; j < contacts.size(); j++)
			if (contacts[j]->getObject() == obj)
				all_contacts.append(contacts[j]);
The result of this function looks like this:
  • silent changed the title to [SOLVED] How can I control collision?? (node)
