carlos.vieira Posted November 14, 2021 Share Posted November 14, 2021 Hi, new to Unigine and c# also... i was trying to build the sample project and i'm getting this: MonoDevelop Build Tool Building csharp_third_person_platformer (Debug) /usr/share/dotnet/sdk/6.0.100/Sdks/Microsoft.NET.Sdk/targets/Microsoft.NET.Sdk.ImportWorkloads.props(14,38): error MSB4236: The SDK 'Microsoft.NET.SDK.WorkloadAutoImportPropsLocator' specified could not be found. /usr/share/dotnet/sdk/6.0.100/Sdks/Microsoft.NET.Sdk/targets/Microsoft.NET.Sdk.ImportWorkloads.props(14,38) : error MSB4236: The SDK 'Microsoft.NET.SDK.WorkloadAutoImportPropsLocator' specified could not be found. I'm using Linux (Ubuntu). Any ideas of what can be happening? I have installed dot net SDK/runtimes 5 and 6. Thanks! Link to comment
silent Posted November 15, 2021 Share Posted November 15, 2021 Hi Carlos, In order to build and develop C# apps you need to have installed .NET 5 SDK only (right now I can see that 6.x SDK is being used instead). Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
carlos.vieira Posted November 15, 2021 Author Share Posted November 15, 2021 Hi, hmmm ok. I removed the SDK 6 and still having some issues with SDK 5 (version 5.0.403): /usr/share/dotnet/sdk/5.0.403/Sdks/Microsoft.NET.Sdk/targets/Microsoft.NET.TargetFrameworkInference.targets(5,5): Error MSB4186: Invalid static method invocation syntax: "[MSBuild]::GetTargetFrameworkIdentifier('$(TargetFramework)')". Method '[MSBuild]::GetTargetFrameworkIdentifier' not found. Static method invocation should be of the form: $([FullTypeName]::Method()), e.g. $([System.IO.Path]::Combine(`a`, `b`)). Check that all parameters are defined, are of the correct type, and are specified in the right order. (MSB4186) (csharp_third_person_platformer) Should I use any specific SDK 5.0.x version? Also, I'm using MonoDevelop, and seems that I can't have autocompletion... can you point me to some of your docs showing the basics to setup MonoDevelop for use with Unigine? Thanks! Link to comment
silent Posted November 15, 2021 Share Posted November 15, 2021 Hi Carlos, What is your current MonoDevelop version? I found similar issues related to the MonoDevelop and it's interaction with .NET 5.0: https://githubmemory.com/repo/dotdevelop/dotdevelop/issues/40 We do recommend to stick with Visual Studio Code under Linux (at least it should have no issues with MSBuild) until Mono will be fully functional. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
carlos.vieira Posted November 15, 2021 Author Share Posted November 15, 2021 Oh ok... I'm using MonoDevelop 7.8.4 (build 2). I'll give Visual Studio Code a try then. Thanks! Link to comment
carlos.vieira Posted November 15, 2021 Author Share Posted November 15, 2021 Hey, I've just tried it with Visual Studio Code and it works Ok :) thanks! 1 Link to comment
