zhengwenxin Posted October 19, 2021 Share Posted October 19, 2021 Hi, I am using the Unigine of version 2.6. I create a decal projected and give it the decal material, but I want to dynamic replace the texture of decal material. I get the material and use the setTextureImage(),but the function return 0. Unigine::MaterialPtr matdecal = Unigine::Materials::get()->findMaterial("decal_base_0"); if (matdecal) { int flag = matdecal->setTextureImage(1, img); matdecal->setTexturePath(1, path.toStdString().c_str()); } Does anyone know how to do? Link to comment
silent Posted October 19, 2021 Share Posted October 19, 2021 zhengwenxin Please make sure that texture slot 1 is the texture that you are really want to set. If you want to change the albedo, first get the albedo texture slot from material: Materials *materials = Materials::get(); MaterialPtr m = materials->findMaterial("decal_base_0"); int num = m->findTexture("albedo"); m->setTexturePath(num, new_texture); Don't forget to check if num is a positive number, since -1 means that such texture slot is not found. You can check how texture slots are named in .basemat file from core directory: Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
