fabre.cedric Posted October 6, 2021 Share Posted October 6, 2021 (edited) Hello, I have a strange bug I think after the 2.13 version of unigine... If I write : XmlPtr nod = Xml::create(); bool result = nod->load("data/Cachees.node"); result return true, my node file is loaded but if I write : XmlPtr nod = Xml::create(); bool result = nod->load("data/Cachées.node"); result return false... I don't understand where is the problem, I have tested on a sample named "Lights" from C++ API and same bug. Could you please confirm there is a bug here because I have many bad returns from our customers :-/. Thanks. EDIT: Our project use Unigine 2.14.1.1 and same bug Edited October 6, 2021 by fabre.cedric Link to comment
bmyagkov Posted October 6, 2021 Share Posted October 6, 2021 Hello! We have able to reproduce the issue and found that the some IDE's could not proceed "UTF8 with BOM" encoding in such a case, there will be following warnings: Quote AppSystemLogic.cpp(29): warning C4566: character represented by universal-character-name '\u00E9' cannot be represented in the current code page (1251' To solve the problem, source code file should be re-saved with UTF8 encoding. It can be tested with the files attached. Thanks! UTF8_AppSystemLogic.cpp UTF8_with_BOM_AppSystemLogic.cpp Link to comment
fabre.cedric Posted October 6, 2021 Author Share Posted October 6, 2021 I will try to record all sources code in utf8 and get back to you. Thanks for this information ! 1 Link to comment
fabre.cedric Posted October 6, 2021 Author Share Posted October 6, 2021 I have tested with your file and that work, but how this is possible ? o.O I thought the generated executable never take into acount the encoding of the source code file ? There is many files in our project now and VS2019 save in UTF-8 Bom that worked before... What's the right way ? Thanks Link to comment
bmyagkov Posted October 7, 2021 Share Posted October 7, 2021 15 hours ago, fabre.cedric said: I have tested with your file and that work, but how this is possible ? o.O I thought the generated executable never take into acount the encoding of the source code file ? There is many files in our project now and VS2019 save in UTF-8 Bom that worked before... What's the right way ? Thanks Hello! Not sure where from this comes exactly, but our own research shown that some of VS2019 builds could not deal with such a case. It seems like the most recent revisions do not have this problem at all. 1 Link to comment
