3danimation Posted September 16, 2021 Share Posted September 16, 2021 Hi What is the code to add a timeline to my project? Is the tracker tool the only option? It seema a but complicated. But its its thr only timeline we can add.. Please provide thr code of how to add it Also. I need the ability to import and export 3d models and save projects and then load saved projects. Please help. Link to comment
silent Posted September 17, 2021 Share Posted September 17, 2021 3danimation You can add tracker (but you would need to write a Tracker wrapper first, since it's uses internally UnigineScript). Sample with tracker in runtime (with no Editor loaded) you can find in SDK Browser -> Samples -> UnigineScript -> Tracker -> tracker_00. For importing / exporting models you can use built-in import system that is available in Engineering / Sim SDKs: https://developer.unigine.com/en/docs/2.14.1/principles/import_system/?rlang=cpp If you need some custom format support, you can write your own importer: https://developer.unigine.com/en/docs/2.14.1/code/usage/custom_import_plugin/index?rlang=cpp Exporting: https://developer.unigine.com/en/docs/2.14.1/api/library/common/export/?rlang=cpp Not sure about save and load projects. If you need to load or save world you can call World::saveWorld() / World::loadWorld() methods. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
3danimation Posted September 21, 2021 Author Share Posted September 21, 2021 The unigine tracker is very unuser friendly and difficult to use. Do u guys have plans to make a better animation time line in the future? Link to comment
silent Posted September 22, 2021 Share Posted September 22, 2021 Sure, we do have plans for tracker usability update, but they are tied to overall animation workflow changes. It's very time consuming task and it's not finished yet. Updated tool more likely wouldn't be available in the runtime and will be Editor-only feature. So, if you would need some similar functionality in your custom app you would need to create your own from scratch (you can probably found similar looking custom widgets in IMGUI). Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
3danimation Posted September 23, 2021 Author Share Posted September 23, 2021 Thank you for the reply Link to comment
werner.poetzelberger Posted September 23, 2021 Share Posted September 23, 2021 Actually I cannot agree, that the tracker is user unfriendly. It does what it should do and if you start working with it, you will find out, that it does it well. I am using it for a long time from the beginning of the Unigine editor. Its the tool which has not changed yet (still the old ui) and it still serves well. Best.w. 2 Link to comment
3danimation Posted September 27, 2021 Author Share Posted September 27, 2021 (edited) And its that "i've been using this for years" attitude that keeps the software from making improvements. Just because u have been using it for years doesnt make it user friendly. It just means u where forced to get used to it. Learn to accept constructive criticism. And just do better. Dont come here to argue. Just improve. The year is 2021 and their tracker tool.looks like it was designed in 1991. Its out dated and incredibly difficult to use. Thats an opinion shared by many. In 20 years Unigine should have made a better timeline. Edited September 27, 2021 by 3danimation Link to comment
silent Posted September 28, 2021 Share Posted September 28, 2021 3danimation If you have any constructive feedback regarding this tool, please submit it to the corresponding subforum: https://developer.unigine.com/forum/forum/19-feeback-for-unigine-team/ I will close this topic, since all the initial questions were answered already. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
