3danimation Posted September 15, 2021 Share Posted September 15, 2021 Hi Two questions After i create the final build 1. I like the Unigine application launcher but is there a way to remove all unigine logo and icon and replace it with my info? 2. Remove system menu when ESC button pressed and replace it with my own custom menu... I have aske how to remove the standard menu and im not sure if this feature is available for community users or pro only. Please help. Link to comment
silent Posted September 15, 2021 Share Posted September 15, 2021 You can already change an image, but not an icon. Icon change would be possible in the next (2.15) release this autumn. To disable built-in menu you need to use -extern_define "MENU_USER", I've already answered in your previous topic: https://developer.unigine.com/forum/topic/7603-adding-gizmo-code-is-not-working/?tab=comments#comment-37832 So you would need to write a code that would draw your menu and handle the ESC press button on your side. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
3danimation Posted September 16, 2021 Author Share Posted September 16, 2021 Ok. Yes u answered the question but i did not understand what u said which is why im asking again. extern_define "MENU_USER", I've already answered in your previous topic: Where EXACTLY is extern_define "MENU_USER" supposed to go???? U said in my other post that i should go to the exe... Ur instructions are not clear to someone who is very new to ur engine. So i keep asking Link to comment
