[SOLVED] Create randomly moving objects
Perhaps this is a too simple question, but I have been sitting with this for a long time.
The task is simple - I need to create a number of identical objects that move in a random direction. I use primitive boxes and add to them a property (c++ code) that generates a move in a random direction. But when launched, they all move in the same direction. Moreover, when restarting, the direction changes, but as before it is the same for everyone. Perhaps I am missing something, but I did not find a solution to this problem in the documentation.
Edited by NotNa19
I have a property where a random direction of movement is set:
Spoiler
#include "BoxMove.h"
#include <ctime>
REGISTER_COMPONENT(BoxMove);
void BoxMove::init()
void BoxMove::update()
	Unigine::Math::Random rd;
	vec3 dir;
	dir = vec3(rd.getInt(-1, 2), rd.getInt(-1, 2), 0);
	vec3 p0 = node->getWorldPosition();
	vec3 p1 = p0 + dir * speed * Game::getIFps();
	node->setWorldPosition(p1);
And I have three boxes with this property:
Spoiler
I want the boxes to move in a random direction, but each box has a different direction.
But they all move in the same, although a random direction:
Spoiler
Will be there any difference if you will use Game::getRandomInt() instead of Math::Random? If that will not work, try to set different seeds each time via Game::setSeed().
I suppose that for Math::Random you need also specify different seeds each time via setSeed() method.
  • NotNa19 changed the title to [SOLVED] Create randomly moving objects
