dongju.jeong Posted August 3, 2021 Share Posted August 3, 2021 It's dark at 13:00. The setup goes wrong somewhere. Link to comment
silent Posted August 3, 2021 Share Posted August 3, 2021 dongju.jeong Are you on the latest 2.14.1.1? It should be fine there. Could you please try to update your project's SDK? Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
dongju.jeong Posted August 3, 2021 Author Share Posted August 3, 2021 my version is 2.14.1.1...... Link to comment
cash-metall Posted August 3, 2021 Share Posted August 3, 2021 Hi what is the entity's geo-location? (from witch you can see night at 13) geocoordinates of default entity are probably unknown at the start - try to set the entity in real geocoordinates (not necessarily in the origin) Link to comment
dongju.jeong Posted August 4, 2021 Author Share Posted August 4, 2021 (edited) Even when an entity is within its geographic range, it is brightened at night... The same is true for creating and running the same GeodeticPivot on the new default ig project. When creating ig with 2.14.1.1 version, ig_config file appears to be creating 2.14.0.0 version.But it seems to be replaced automatically to 2.14.1.0 when the project is first launched. end Is it normal for logs to display 2.14.1.0 or 2.14.0.0? Edited August 4, 2021 by dongju.jeong Link to comment
cash-metall Posted August 4, 2021 Share Posted August 4, 2021 2 hours ago, dongju.jeong said: Even when an entity is within its geographic range, it is brightened at night... i compare IG result and Stellarium(free open source planetarium) - results look roughly similar location near your pivot (Hwaseong-si 37°12'24.6"N 126°49'00.9"E or 37.206822, 126.816903) sunrise 2004-04-06 at 22 UTC0 or 7 UTC+9 (console command datetime show current datetime in both format) noon at 4 UTC0 or 13 UTC+9 and sunset at 9 UTC0 or 18 UTC+9 maybe you check with a debugging camera(ig_debug 1)? the geographic position is not updated for it. Or does the sun in the world have any additional settings? check on an empty project please. UPD: just noticed that in the stellarium the camera was looking to the south but not to the north. but this does not affect the result. Link to comment
dongju.jeong Posted August 4, 2021 Author Share Posted August 4, 2021 (edited) it's same with debugging camera. this is a result in empty ig project. ( I just create GeodeticPivot) Edited August 4, 2021 by dongju.jeong Link to comment
dongju.jeong Posted August 4, 2021 Author Share Posted August 4, 2021 (edited) unigine_project.7zthis is sample empty ig project. Or should I erase the latest version of sdk and reinstall it? Edited August 4, 2021 by dongju.jeong 1 Link to comment
dongju.jeong Posted August 4, 2021 Author Share Posted August 4, 2021 (edited) I understand it. this time is utc 07:00 ? korea time is utc+9. then, utc 07:00 is 16:00 of korea time.? However, if time_zone is set to 0 or 9 in ig_config, nothing changes in ig. There are very slight changes.There seems to be an hour or two difference. Edited August 4, 2021 by dongju.jeong 1 Link to comment
cash-metall Posted August 4, 2021 Share Posted August 4, 2021 I'm sorry, I'm really stupid. this fix was not included in 2.14.1.1, but I have erroneously marked that it was included. please set timezone 90 instead of 9 (9 * 10 damn, we lost of zero...) once again I apologize for your wasted time. 1 Link to comment
dongju.jeong Posted August 4, 2021 Author Share Posted August 4, 2021 ok. thank you. Time is operating normally. Link to comment
