dongju.jeong Posted July 29, 2021 Share Posted July 29, 2021 (edited) I cleaned up the guid using the Cleaner tool, erased the .runtimes folder and guid file, and ran the editor again, but the error was not resolved. What should I fix? Edited July 29, 2021 by dongju.jeong Link to comment
silent Posted July 29, 2021 Share Posted July 29, 2021 dongju.jeong Cleaner tool can't actuall fix all the errors of your project. In order to give you more information we would need to check your project first. Try to find out from where this guids are comes from (check guids.db and all the .node / .mat / .meta / .world files). That can be some missing files from the light baking, that probably doesn't affect the project at all. Thanks! 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
dongju.jeong Posted August 3, 2021 Author Share Posted August 3, 2021 Guids.db does not contain problem guid. There is an error in the console of the editor, is it related to a guid error? Link to comment
vvvaseckiy Posted August 3, 2021 Share Posted August 3, 2021 Hi dongju.jeong, This error can't occur cause of .meta files without the referenced asset. Usually it happens when you delete file but not it's .meta by using OS file manager. Or it might happen when you delete file in your VCS but the .meta stays versioned. We will improve this behavior in future releases by additional validation of lost assets, but for now you can only fix this manually. Not very convenient, but the fastest way to locate .meta files without assets is to search with GUID from error through guids.db, and then, manually delete .meta from lost asset. 1 Link to comment
dongju.jeong Posted August 6, 2021 Author Share Posted August 6, 2021 vvvaseckiy I searched for error guid in guids.db but couldn't find it.I found the meta file directly in the file explorer and erased it. Link to comment
