fred.naar Posted June 21, 2021 Share Posted June 21, 2021 Hello I am trying to create a complete copy of the runtime assets generated during an FBX import to a custom folder. So basically what I would like to end up with is a folder structure just made of a main node and all native assets like this: myasset.node Textures/ ... all dds textures Meshes/ ... all mesh files Animations/.. all animation files Materials / ... all materials pointing to the proper dds textures So created an AssetImporter.cs component with a public parameter [ParameterFile] public string AssetPath; then on a keydown event I do var guid = FileSystem.GetGUID(AssetPath); string target = "test"; var newguid = FileSystemAssets.CopyRuntime(guid, target); but this does not work,as the refered guid is not the fbx file itself but the node within the fbx... I also tried to iterate through the runtimes like this but num runtimes ==0... int numruntimes = FileSystemAssets.GetNumRuntimes(guid); for (int j = 0; j < numruntimes; j++) { var runtimeguid = FileSystemAssets.GetRuntimeGUID(guid, j); Log.Message("\nguid " + guid.ToString() + " runtime " + runtimeguid.ToString() + " - Copied at " + target); } I also tried to use the new AssetLinkNode C# functionality in order to load the node and have the node hyerarchy there but could not make it work either... what would be the best way to do this ? thanks Fred Link to comment
karpych11 Posted June 21, 2021 Share Posted June 21, 2021 Hello, Try to use FileSystemAssets.GetAssetGUID(path) instead of FileSystem.GetGUID(path). In this case, you will get correct number of runtimes. In attached sample, I am trying to copy runtimes to custom folder.CopyAsset.cs 1 Link to comment
