Amerio.Stephane Posted March 11, 2021 Share Posted March 11, 2021 Hello, In the current experimental sandworm, a ".sandworm_cache" folder is created alongside the bin folder, and this folder size can get very huge. Due to IT constraints, our bin folder must be in a specific location, which have a strong disk quota limitation. All our data subfolders are stored via mount points on some other disk with no such limitation. So, is there a way to set the location of this ".sandworm_cache" folder and not fill-up our system disk? Thanks! Link to comment
bmyagkov Posted March 11, 2021 Share Posted March 11, 2021 Hello! As I know you can't change cache folder by current implementation. Since tool was mention as experimental cache path was hard-coded and has no way to be changed. In our internal version, you can specify the location of the cache folder and this functionality as well as others will be available in the following release 2.14 already in the next month Link to comment
Amerio.Stephane Posted March 11, 2021 Author Share Posted March 11, 2021 Great news, then! I'm eager to test the upcoming version! Link to comment
