dongju.jeong Posted February 2, 2021 Share Posted February 2, 2021 (edited) Is there a tip to ensure that masks are applied to fields, and forest areas only? Currently, I have a problem that masks are applied to unwanted areas or that masks are not applied exactly to desired areas. I changing the color of the land to express autumn. my setting.. The mask file is the same as the albedo file. Edited February 2, 2021 by dongju.jeong Link to comment
bmyagkov Posted February 2, 2021 Share Posted February 2, 2021 Hello! I didn't quite understand what for you are changing Textures > Albedo > Color? It will does not give any effect on mask threshold, but it is greatly imagine "unwanted areas" that you want to show. Oh, looks like i got it. The only way that you could prevent this "unwanted areas" It is adjust colors threshold more accurately. As I can see that you are used a lot of colors layers here, usually you need much less of them to have a decent result. Try to leave only "green" colors and adjust their threshold. For example, what for you need "316178" here, which is looks like blue and obviously it will also apply to "unwanted ares" for sure like water or other "blue" areas. Adjusting this settings could also help a bit. Even so, it will be difficult to achieve the perfect result, since the pixels of different colors will be located all over the place. If you want to get the perfect coverage, then you need to use your own masks, prepared in some of third-party applications. Or for example you could use single-channel masks like this one for example Thanks! 1 Link to comment
dongju.jeong Posted February 4, 2021 Author Share Posted February 4, 2021 thanks.It has improved considerably. 1 Link to comment
sergej.paramonov Posted February 18, 2021 Share Posted February 18, 2021 bmyagkov, посоветуйте пожалуйста в каких приложениях можно сделать одноканальные маски Link to comment
bmyagkov Posted February 19, 2021 Share Posted February 19, 2021 12 hours ago, sergej.paramonov said: bmyagkov, посоветуйте пожалуйста в каких приложениях можно сделать одноканальные маски Для создания одноканальных масок подойдет любой 2d-редактор, хватит самого простого, например даже входящего в базовый комплект приложений Windows - MS Paint Link to comment
sergej.paramonov Posted February 20, 2021 Share Posted February 20, 2021 21 hours ago, bmyagkov said: Для создания одноканальных масок подойдет любой 2d-редактор, хватит самого простого, например даже входящего в базовый комплект приложений Windows - MS Paint А как потом сделать геопривязку? Link to comment
bmyagkov Posted February 20, 2021 Share Posted February 20, 2021 55 minutes ago, sergej.paramonov said: А как потом сделать геопривязку? Можно геопривязать, при помощи приложения Global Mapper, например 1 Link to comment
