Suggestion for showing selected node info
Quite often, I use in the Editor the Helper "Show Selected Node Info", eg. when tuning LOD distances or when evaluating a mesh density. But the text is centered on the bounding box of the object, and can block the view of quite a large part of the object sometimes.
As the node info is only visible when only one node is selected, I would suggest you display it instead in the lower left corner, so it will not prevent viewing the mesh (or at least maybe make it an option).
