manuel.gysin Posted August 9, 2011 Share Posted August 9, 2011 Hello alt-tab does not work for switching the active application while engine is in fullscreen mode. This only apply with the linux version. Greets Manuel Link to comment
danni.coy Posted August 9, 2011 Share Posted August 9, 2011 Hello alt-tab does not work for switching the active application while engine is in fullscreen mode. This only apply with the linux version. Greets Manuel Concidering the following a work-around /workflow tip. This probably does want to be a feature request. If you are working between multiple applications and need to switch a lot I would suggest making the window the same size as your screen and configuring that window to not draw window decorations (you can do this in KDE at least). It emulates the look of fullscreen (a little slower than actual fullscreen) but Is much easier to use along side other applications. Link to comment
manguste Posted September 23, 2011 Share Posted September 23, 2011 Our developers will implement this feature. Link to comment
manuel.gysin Posted September 23, 2011 Author Share Posted September 23, 2011 Our developers will implement this feature. Great, thanks! Link to comment
manuel.gysin Posted October 13, 2012 Author Share Posted October 13, 2012 Great, thanks! Any news on that? Does not work in the latest SDK. Link to comment
frustum Posted October 13, 2012 Share Posted October 13, 2012 You can use "video_fullscreen 2" video mode. Link to comment
manuel.gysin Posted October 16, 2012 Author Share Posted October 16, 2012 You can use "video_fullscreen 2" video mode. Thanks will test it with the beta sdk. :) Link to comment
