Animated impostors (With FlipBook)
What about reusing current imposter (in order to have different images at different angles), and alter shader to switch UV offset/or switch texture with time.
Is that possible? Or all imposter thing completely "private"?
You can try to modify imposter shader for your needs, maybe it will work. It's hard to tell, because it's quite specific material.
All the shader code you can find in <SDK>/data/core/shaders/billboards/impostor
In order to see the shader changes in your project you need to copy all the modified files to the same data directory inside your project (<YourProject>/data/core <...>).
