deniz.diktas Posted August 8, 2011 Share Posted August 8, 2011 Hi all, we have many models in 3ds max with textures and we want to export these models along with their texures to use them in unigine editor. We exported the models but we could not see the corresponding textures. Since we have many textures (about 130) we do not want to assign the textures in the Unigine editor one by one again. How can we do this ? Any help is highly appreciated. ps: We use 3ds-max 2011. Link to comment
ulf.schroeter Posted August 8, 2011 Share Posted August 8, 2011 we have many models in 3ds max with textures and we want to export these models along with their texures to use them in unigine editor. We exported the models but we could not see the corresponding textures. Since we have many textures (about 130) we do not want to assign the textures in the Unigine editor one by one again. How can we do this ? Any help is highly appreciated. You can use 3DMax-Plugin node export. It's not recommended by UNIGINE but anyway it generates basic node and material files which can be imported with UNIGINE editor and fine-tuned (with respect to material parameters, properties etc. only available within UNIGINE environment). Also it will collect and convert textures (UNIGINE image_dds tool used, so ensure UNIGINE bin folder is on your system path) Link to comment
hintuc_de Posted August 10, 2011 Share Posted August 10, 2011 Node export had errors in UnigineMenu.ms (max script). 1. imagedds_x86 don't have "-n" params and normal map cann't export. 2. specular map cann't export if it set in second type specular material. 3. Object is invisible if it hasn't manual changed materials. Link to comment
hintuc_de Posted August 11, 2011 Share Posted August 11, 2011 3. 3.1. Macros "export node" have errors in creating directories tree before saving files. 3.2. Need first add material library before import node in UnigineEditor. If Node import at first then Node will be invisible after saving and starting at second time. Link to comment
hintuc_de Posted August 12, 2011 Share Posted August 12, 2011 4. map 1 cann't export in "export mesh" and "export node" Link to comment
hintuc_de Posted August 12, 2011 Share Posted August 12, 2011 sorry, it's internet lag Link to comment
manguste Posted August 20, 2011 Share Posted August 20, 2011 Point taken. But we strongly recommend to stick to Mesh export instead of Node export. Otherwise, your material system won't be as performance-efficient as it could be if created manually and result in lower FPS. Besides it, a proper hierarchy is more convenient to edit, because you can change 1 parent material parameter instead of tweaking all materials. Link to comment
