rafal.kasza Posted August 7, 2011 Share Posted August 7, 2011 Hi, I want to make such simulation: wind goes through window and the cloth is waving. I want to simulate only the part of cloth that is near opened window. If the window is closed or slightly opened the curtain should waving more gently. As i see the wind can be set for entire cloth only, am i right? Rafal Link to comment
ulf.schroeter Posted August 8, 2011 Share Posted August 8, 2011 I want to make such simulation: wind goes through window and the cloth is waving. I want to simulate only the part of cloth that is near opened window. If the window is closed or slightly opened the curtain should waving more gently. As i see the wind can be set for entire cloth only, am i right? yep, you are right. Your use case sounds quite special and I would expect some specific UNIGINE script code will be required to achive the desired effect. For reduced wind influence on curtains farer away from the window you might use PhysicalWind::setLinear/AngularDamping(), so wind intensity will be reduced towards wind box edges. Different wind reactions within parts of a single curtain might be possible by reducing particle mass for particles which should wave stronger. See BodyParticles::setParticleMass(). Alternative idea would be to explictly set particle velocity for unaffected part to 0 via BodyParticles::setParticleVelocity(). In both cases affected particles near/far to opened window could be spatially identified via BodyParticles:getParticlePosition() and some window area boundig box testing. Link to comment
frustum Posted August 8, 2011 Share Posted August 8, 2011 Just create PhysicalWind inside the opened window. PhysicalWind will affects only inner cloth particles. Link to comment
ulf.schroeter Posted August 8, 2011 Share Posted August 8, 2011 Just create PhysicalWind inside the opened window. PhysicalWind will affects only inner cloth particles. as always: frustum finds the most simplistic solution... Link to comment
