demostenes Posted October 5, 2020 Posted October 5, 2020 (edited) Recenty I have this crash just after editor start. From the log I am unable to find out, which textures are causing that (Direct3D11 error: device removed ERROR: D3D11Texture::create(): can't create ATI2 2048x2048 2D texture ERROR: Direct3D11 error: device hung ERROR: Direct3D11 error: device removed ERROR: D3D11RenderContext::create_context(): CreateSwapChain():........), but by experimenting I ve found, that it is probably caused by .exr textures from quixel mixer (it crashed just after adding displacement map). Only workaround is to delete . runtime and it will work (even thouse "problematic" textures) until next start of unigine, than I have to delete runtime again. It is the first time, I am using this workflow, before I was always converting textures to .dds before importing to Unigine. Replication would be very problematic, you need to import texture, shut down unigine (if there is no crash) and try to start several times, until this happens. ceeling_bok_Displacement.7z Edited October 5, 2020 by demostenes
silent Posted October 5, 2020 Posted October 5, 2020 Hi Jirka, Thanks for the test texture. Will try to reproduce this crash first in order to get the idea how to fix it. Is that on regular desktop with dedicated GPU with a lot of VRAM? How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
demostenes Posted October 5, 2020 Author Posted October 5, 2020 (edited) 1 hour ago, silent said: Hi Jirka, Thanks for the test texture. Will try to reproduce this crash first in order to get the idea how to fix it. Is that on regular desktop with dedicated GPU with a lot of VRAM? Sure, 16 Core Ryzen, 64GB RAM, 11GB VRAM. Thanks. Edited October 5, 2020 by demostenes 1
vvvaseckiy Posted October 6, 2020 Posted October 6, 2020 Hi demostenes, Sorry, but we could not reproduce this issue with the attached texture. Judging by mentioned errors it could be caused by several reasons, so please provide some additional info: 1. Please check if it's reproducible on latest GPU Driver 2. Specify image importing options(Image Type, Image Format e.t.c.) 3. Check if issue reproducible with CPU Image Compression(Settings/Editor → Uncheck "Use GPU Compression") 4. It might be caused by some set of several textures. Please tell us if it is possible to find this textures in you repo? Or is this issue reproducible in new project? Thanks
demostenes Posted October 7, 2020 Author Posted October 7, 2020 (edited) On 10/6/2020 at 10:08 AM, vvvaseckiy said: Hi demostenes, Sorry, but we could not reproduce this issue with the attached texture. Judging by mentioned errors it could be caused by several reasons, so please provide some additional info: 1. Please check if it's reproducible on latest GPU Driver 2. Specify image importing options(Image Type, Image Format e.t.c.) 3. Check if issue reproducible with CPU Image Compression(Settings/Editor → Uncheck "Use GPU Compression") 4. It might be caused by some set of several textures. Please tell us if it is possible to find this textures in you repo? Or is this issue reproducible in new project? Thanks Hi, 1) With latest driver no change 2) Default import options ( + normal flagged as normal, sometimes inverted G), albedo, metalness, normal are png, displacement is .exr 3) Todays test with latest GPU drivers: Run Unigine -> imidiate crash after start with default world Delete .runtime, run Unigine -> OK Shut down Unigine, run Unigine -> imidiate crash after start with default world Delete .runtime, run Unigine -> OK, set compression to CPU Shut down Unigine, run Unigine -> imidiate crash after start with default world Delete .runtime, run Unigine -> OK Shut down Unigine, run Unigine -> imidiate crash after start with default world So it does not seem, that GPU compression has anything to do with it. 4) I didnt commit these new files to the main branch, because it would break project for anybody else. I will commit it to branch and let you know. Thanks. Edited October 7, 2020 by demostenes
demostenes Posted October 12, 2020 Author Posted October 12, 2020 On 10/6/2020 at 10:08 AM, vvvaseckiy said: .... I ve sent you to PM details regarding repository and where to download this branch.
vvvaseckiy Posted October 14, 2020 Posted October 14, 2020 Thank you for additional info. We successfully reproduced this crash, it seem that it occurs cause of the .exr texture used as displacement map in some materials. I've forwarded this issue to our dev team, we'll try to fix it in upcoming 2.13 stable release 3
vvvaseckiy Posted October 16, 2020 Posted October 16, 2020 A small update from our dev team. The issue actually is caused by non-normalized data in .exr and enabled "Mipmaps SRGB Correction" import option, which is not quite valid for this image format. We will improve this behavior in future release. Meanwhile you can disable "Mipmaps SRGB Correction" option and reimport .exr texture.
demostenes Posted October 20, 2020 Author Posted October 20, 2020 On 10/16/2020 at 5:46 AM, vvvaseckiy said: A small update from our dev team. The issue actually is caused by non-normalized data in .exr and enabled "Mipmaps SRGB Correction" import option, which is not quite valid for this image format. We will improve this behavior in future release. Meanwhile you can disable "Mipmaps SRGB Correction" option and reimport .exr texture. Great, thanks!
