String property parameter not working as expected
I have a problem with changing a property parameter that is of string type
____________________________________________________________________________________
#include <UnigineGame.h>
#include "UnigineComponentSystem.h"
class MaterialPaintingController final : public Unigine::ComponentBase
       COMPONENT(MaterialPaintingController, Unigine::ComponentBase);
       COMPONENT_INIT(init);
       PROP_NAME("MaterialPaintingController");
       PROP_PARAM(String, painting_variant, "DEF");
       PROP_ARRAY(Node, surfaces);
       void init();
       void parameterChanged(Unigine::PropertyPtr property, int propID);
then I use setParameterData in the call
    Unigine::String str("NewMat");
     componentPtr->setParameterData("painting_variant", &str);
I did not get a callback for a change and I can't find out what's going on.
Is the use of setParameterData correct ?
thanks for any help.
Michal
Hello michal,
how are you creating "componentPtr"?
SetParameterData is a member of the class IG::Component.
MaterialPaintingController inherits from Unigine::ComponentBase. Therefore it should not have setParameterData as member.
So apparently you are instantiating the wrong class.
This should help you accessing parameters after instantiating the correct class.
Best regards
I have this custom component "MaterialPaintingController" , which I added to my  EntityObject.node in the Editor .
When I want change parameter value , I use this :
              void set_property_value(EntityID id, Component comp, PropertyName name, Unigine::String const& data)
                     if (auto igEntity = ig_manager::get().getEntity(id))
                           if (auto componentPtr = igEntity->getComponent(static_cast<int>(comp)))
                                  componentPtr->setParameterData(PropertyNamesDefines[static_cast<int>(name)], &data);
for Float and Int version it is working , now I am trying to use String as parameter
18 minutes ago, ipg_rom said:
Can you try to use "data.get()" instead of "&data"?
yeah , this not helps. As I sad ,I am not sure if setParameterData function is appropriate for setting String parameter.  PROP_PARAM(String, painting_variant, "DEF"),
but there are only setParameterData, setParameterFloat, setParameterInt .
Hi!
You can try this:
if (auto cs_component = ComponentSystem::get()->getComponent<MaterialPaintingController>(igEntity->getNode()))
   cs_component->painting_variant = data;
5 hours ago, moroz said:
Hi!
You can try this:
thanks , this working for me . Actually
            if (auto cs_component = Unigine::ComponentSystem::get()->getComponent<MaterialPaintingController>(igEntity->getNodeReference()->getReference()))
                cs_component->painting_variant = materialName.c_str();
but I am still curious about usage of "setParameterData" in IGPlugin , respectively how to set parameter different of "Int" and "Float".
Anyway thank you for the help.
Michal
6 hours ago, silent said:
michal
Unfortunately, it's not possible. IGPlugin was designed with CIGI API limitations in mind (and there is no other data other than int and float).
I understand that , thanks you let me know
Michal
