[SOLVED] ObjectMeshStatic::getColor bug
Shouldn't
vec4 ObjectMeshStatic::getColor(int num, int surface) const
	return vec4(mesh_ptr->getColors(surface)[num]) * 255.0f;
actually be:
	return vec4(mesh_ptr->getColors(surface)[num]) * (1.f/255.0f);
since mesh_ptr->getColors returns in 0..255 range and you want to output in 0..1 and not the other way around?
Kind Regards,
Adrian L.
  • silent changed the title to [SOLVED] ObjectMeshStatic::getColor bug
