SLI, appVarjo support
In the release of Varjo Base, Varjo Base supports SLI.
Does the performance improve when using the appVarjo of Unigine in the SLI environment?
https://varjo.com/downloads/release-notes/#varjo-base
Varjo Base, release version 1.2.1
May 8, 2019
WIP for SLI systems support (current initialisation times for SLI could be up to 30 seconds)
More robust and fast USB initialization
Optimised In-HMD CPU performance
modori
We do not support SLI VR (since in requires implementing vendor-like extensions). Our tests with single GPU was pretty much OK in terms of performance, so there will be no performance improvements if you will enable SLI in driver settings (more likely you will get performance drop instead).
