[SOLVED] WidgetWindow isn't resized
WidgetWindow exampleWin;
exampleWin.setWidth(100);
exampleWin.setHeight(100);
xml (User Interface file)
<window name="Test::exampleWin" width="100" height="100">
<text>exapmple</text>
</window>
This is a peculiar feature of a window. You can control its size only if you set parameter sizeable="1", but in this case user can control its size too.
Alternatively, you can use a widget container to control a window size.
string UI_PATH = "test/test6.ui";
Gui gui;
UserInterface ui;
WidgetVBox container;
int init() {
    gui = engine.getGui();
    ui = engine.gui.addUserInterface(gui,UI_PATH);
    container.setWidth(200);
    container.setHeight(400);
    gui.addChild(exampleWin);
<ui version="1.0">
    <window name="exampleWin" export="1" snap_distance="16">
         <vbox name="container" export="1" width="300" height="300"> </vbox>
    </window>
</ui>
  • 1 year later...
And you can lock the scale of one of the sides of the window, or change the size to the maximum value?
For example in a chat in horizontal window does not change size, but on the vertical of the possible.
  • 1 month later...
