find_me Posted July 28, 2020 Share Posted July 28, 2020 So I understand that {Metalness, Roughness, Specular} can be defined by a single texture file with the corresponding {R,G,B} channels in the metalness workflow. Also that while importing textures, you can set a preset for that specific texture asset to work in such field or another. However the real question follows: How do I turn 3 separate Black&White metalness, roughness, & specular texture files into a single texture file with the appropriate color channels RGB. Followup question, is this something easily done through Unigine, or is this something I should use a third party software for. I'm currently trying to figure out how to manipulate the black an white textures in Gimp to mask into a single texture... But that is a bit challenging as well considering I am very new to texture & material design. Link to comment
silent Posted July 29, 2020 Share Posted July 29, 2020 find_me You don't need to manually convert grayscale textures, just copy them as-is into the specific channel in your DCC tool. Alternatively, you can use Substance Painter with configured export preset for shading texture or third-party generators: Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
find_me Posted July 29, 2020 Author Share Posted July 29, 2020 Thank you very much that is loads of help! Link to comment
