davide445 Posted July 7, 2020 Share Posted July 7, 2020 (edited) Created a node for trees impostors that need to be spawn over a specific mask, but in fact they are cut off at a certain height Using the Mask Terrain to control his position, but changing Size X and Y and all the other parameters change the appearance but not the fact the trees are not applied below that level. The mask of course is extended on all the surface up to the bottom point of the Terrain. Edited July 10, 2020 by davide445 Link to comment
morbid Posted July 8, 2020 Share Posted July 8, 2020 Hello Davide, Please try setting Angle value to 0. Will it help? Thanks. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
davide445 Posted July 8, 2020 Author Share Posted July 8, 2020 (edited) Hello morbid, already tried a bit all the options I can think about, included the Angle to 0. Indeed increase the coverage, but not below previous level Tried increasing size, changing step, subdivision, Treshold do 0, Min visibility to 0, min fade to 150, disabled thinning, etc. Attached the height map and the mask I'm using to positioning the trees height_mask.rar Edited July 8, 2020 by davide445 Link to comment
werner.poetzelberger Posted July 8, 2020 Share Posted July 8, 2020 Just what I see from here, your clutter object ends here and has a very weird rotation ... Did u position it correctly? Link to comment
davide445 Posted July 8, 2020 Author Share Posted July 8, 2020 1 minute ago, werner.poetzelberger said: Just what I see from here, your clutter object ends here and has a very weird rotation ... I didn't create any cutter object... The problem is exactly this one, they are "cutted off" at this strange height and I didn't understand why Link to comment
werner.poetzelberger Posted July 8, 2020 Share Posted July 8, 2020 (edited) But which node is this? Impostor grass? Look where the Pivot is. btw I didnt mean CUTTER. but CLUTTER. Edited July 8, 2020 by werner.poetzelberger Link to comment
davide445 Posted July 8, 2020 Author Share Posted July 8, 2020 (edited) An ObjectGrass. Ok now read correctly, clutter. I dind't positioned it, just select the Mask Terrain for the Pine mask. Selecting Slope mask they are correctly positioned on the slopes, but again up to this height Edited July 8, 2020 by davide445 Link to comment
morbid Posted July 9, 2020 Share Posted July 9, 2020 @davide445, I can take a look if you'll give me this heightmap and mask source files. Thanks. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
davide445 Posted July 9, 2020 Author Share Posted July 9, 2020 @morbid attached in this post Link to comment
morbid Posted July 9, 2020 Share Posted July 9, 2020 Seems okay to me. Check the attached scene (based on 2.11). Maybe I missed something? How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
davide445 Posted July 10, 2020 Author Share Posted July 10, 2020 I was testing your ObjectGrass in my original Landscape and give the same problems, so something odd was going on in my Landscape setup. Returning back to the origin, I noticed you have all on 0,0,0 so I tried to restore to 0 on the Landscape (I have rotated it for reasons I didn't remeber and so all other elements are also shifted and/or rotated respect the origin). In this way after resetting the Mask Terrain and recreating the Details all is fine 1 Link to comment
