Detecting slave connection/disconnection
- Is there a callback for when a slave has connected/disconnected?
- How can we get the "name" the slave was set up with (through the command line -sync_slave_name)?
Hello Stephane,
You're working with 2.11, right?
In the latest version all of these features are available.
Master has SLAVE_CONNECTED, SLAVE_DISCONNECTED
And slave: MASTER_CONNECTED, MASTER_DISCONNECTED
Here you'll find the detailed description: https://developer.unigine.com/en/docs/2.11/api/library/plugins/syncker/class.masterinterface?rlang=cpp
Name was removed and changed to an ID. You can use getSlaveID or getSlaveAddress and getSlavePort.
Actually, we're still on 2.10 (and looking into the effort of moving to 2.11).
The callbacks you mentioned exist only starting from 2.11, so I guess this is one more reason to make the shift :)
About sync_slave_name: I guess we should use sync_view instead, but I'm wondering if the behavior would be the same, as we are not using any wall/projector/multiscreen config file, so the name we use are simply "made up". Would it still be ok?
The objective: each slave should announce at connection time the name of the player it wants to be attached to, through the command line (this player can later be changed through a custom menu).
