HAT/HOT response
I think HAT/HOT Response value is not chaged by  Entity's Roll,Pitch changing. (test with Hemu, Unigine 2.9)
but It is change by Entity's Heading(Yaw).
I want this value to be affected by roll and pitch too.
Is it normal for HAT / HAT not to be affected by roll and pitch?
HAT (Height Above Terrain) and HOT (Height of Terrain) should NOT depend on the entity yaw/pitch/roll if the HAT/HOT has no offset from the CG of the entity. By definition, HAT/HOT are always traced by a vertical line.
If you need the traced line to be attached to the entity (hence modifying the traced length with the yaw/pitch/roll) you should use a LOS (Line Of Sight) vector or segment.
  • Like 3
