Visualize::renderVector() bug?
I was playing with Visualize::renderVector() and found this,
not sure this is a bug but I feel it is not right.
I use this function in 2 cases (the first one is commented block)
Case 2 is ok, visualized vector display with exact start/end position
In case 1,  when I replace start/end Vec3 postion by using 2 objects (a moving airPlane model and static material_ball), I got this
Yes, it fixed the problem, I did not use Visualizer::setSize() before, that means default size of renderVector is too big?
  • 1 year later...
render this 2 points and You`ll get wrong end position!
