dongju.jeong Posted May 13, 2020 Share Posted May 13, 2020 this unigine excutable is VR. so framerate is 45 or 90. However, even if the frame is 45, the gpu loads less than 60 percent. Can you deliberately make the gpu load rate more than 90 percent? Link to comment
morbid Posted May 13, 2020 Share Posted May 13, 2020 Hello, At first, try to degrade rendering quality and check if this will this give you stable 90 FPS in VR. If not, you might be blocked by the CPU. Otherwise, you might be limited with SteamVR that cuts the frame rate to 45 (and this leads to a lower GPU usage). You can't directly control it. Thanks. 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
