What is the function setZNear doing on a LightProj
Ok this is not very clear to me, so what happens exactly? When an object or pixels distance to the light is smaller than the near clipping value it should not be lit?
Basically, this parameter affects how the shadow of the lit objects should look like.
With fully deferred rendering you can't simply disable light from a specific surface of the mesh (I assume that you would trying to do with changing the ZNear parameter).
Ok so this is only for shadows and not illumination in your engine.There is no information in the documentation, add it please :)
Well I am sure it is possible in deferred rendering if the shader is implemented to compare distance to light source with ZNear parameter for illumination :)
