a numbers of bugs reported in unigine 2.11
Hi Unigine Team,
WOW , you Unigine corp team are vey fast , I THANK YOU VERY MUCH for unigine 2.11.0.1.
I found a few bugs in unigine 2.11 not  2.11.0.1 , I tested a lot but I think this is a list bugs :
01- Cloth in Physics Type (Bug Does not Work)
02-Fracture in Physics Type (Bug & does not work)
03- Field Weather node (Crash) , Where is Snow or Rain parameters ??
4- I downloaded VFX 2.11 but SDK Brower detected for Unigine 1 not Unigine 2.11
5- When I set Spread param to zero , then I re-change Spread param to none-zero , example one , particle will be hidde (Spread param Bug)
Edited by ahmad.karami
Hello ahmad,
Could you please provide a more specific reproduction steps for described bugs, you can refer to this article when submitting a bug.
* Cloth & Fracture bodies have specific requirements for mesh they assigned to. You can check out body rope & body fracture implementations in UnigineScript Samples → Physics
* We could not reproduce Field Weather Crash with only this object, it could be caused by multiple objects in scene, Please provide more specific reproduction steps or a small test scene.
Snow & Rain weather effects cannot be implemented through basic parameters of field weather object. You can check out basic implementation of such effects in UnigineScript Samples and VFX Addon. Or in Weather Add-On which available for Engineering & Sim SDK Editions
* Regarding using addons, you shouldn't be adding addon as project, addon is added on creation or reconfiguring of your Unigine Project. Please refer to this article:
* We successfully reproduced bug with Particles spread parameter. It will be fixed in next release
4 hours ago, vvvaseckiy said:
Hello ahmad,
Hello Mr @vvvaseckiy
Thank you so much for great tips & your information , ok , I try again , I reproduction this issues :-)
GREAT Mr @vvvaseckiy  , You Solved My Problems , Thank you so much :-)
