Amerio.Stephane Posted March 19, 2020 Share Posted March 19, 2020 Hello, I know 2.11 is on its way, so this is a suggestion for the NEXT version: - Add the possibility in ig_config.xml to define a default node when an entity type is requested by the host but not defined: Exemple: <entity_types> <entity id="1.2.71.1.1.0.0" name="Mirage"> <!-- exact representation --> <path>ig/entities/aircrafts/mirage/mirageFR.node</path> </entity> <entity id="1.2.71.-1.-1.-1.-1" name="FrenchFighter"> <!-- a generic fighter jet, with FR livery --> <path>ig/entities/aircrafts/fighter/fighterFR.node</path> </entity> <entity id="-1.-1.-1.-1.-1.-1.-1" name="Unknown"> <path>ig/entities/dis/unknown.node</path> <!-- a simple red cube? --> </entity> <entity id="200" name="be-200"> <path>ig/entities/aircrafts/be-200/be_200.node</path> </entity> <entity id="-1" name="Unknown"> <path>ig/entities/cigi/unknown.node</path> <!-- a simple yellow cube? --> </entity> This would be very helpful when integrating an existing scenario, as we would at least SEE something instead of nothing (and wonder if the network is ok...) (note also that this is why it's important to be able to query via API an Entity to know its DIS type or CIGI type, not the internal type, for debug purposes). (note the "-1" above are just a suggestion, maybe a "*" would be better for legibility) Thanks ! Link to comment
morbid Posted March 20, 2020 Share Posted March 20, 2020 Thanks, added to the feature request list. I'll be able to update ETA after the release. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
