dongju.jeong Posted January 31, 2020 Share Posted January 31, 2020 (edited) Instead of setting the particle clamp on the particle system node(deflectors), Does exist the effect of particles disappear when they collide with other objects? Edited January 31, 2020 by dongju.jeong Link to comment
dongju.jeong Posted January 31, 2020 Author Share Posted January 31, 2020 If each value of position up to 32, the value is fixed. Link to comment
morbid Posted January 31, 2020 Share Posted January 31, 2020 Hello Dong Ju, I think you've already found that particles deflector can work as a clipper. 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
morbid Posted January 31, 2020 Share Posted January 31, 2020 Sorry, I don't understand, which value is fixed? Deflector should be within particle system boundbox to work properly, you moved it away for some reason. Could you please explain the case? Thank you. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
dongju.jeong Posted January 31, 2020 Author Share Posted January 31, 2020 I want to put a clamp object on top of a moving object because of the problem like the picture. Is there any other way than the particle's deflector ??? Link to comment
morbid Posted January 31, 2020 Share Posted January 31, 2020 Assign a physical body to the helicopter and enable culling and collision flags in the particles. Use collision mask for the shape and particles surface to configure which surfaces should cull the particles. 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
dongju.jeong Posted January 31, 2020 Author Share Posted January 31, 2020 it is very helpful. but too many heavy... I trying to coding the deflector to follow a particular moving object in runtime. is it possible? Link to comment
dongju.jeong Posted January 31, 2020 Author Share Posted January 31, 2020 (edited) 2 hours ago, morbid said: Sorry, I don't understand, which value is fixed? Deflector should be within particle system boundbox to work properly, you moved it away for some reason. Could you please explain the case? Thank you. In the case of position, if a number is placed beyond the particle range, it is fixed at -32.In case of rotation, if I try to change the value a little bit, it is fixed at 360. (I changed the value with a mouse drag.) and I can't set value return to 0 Edited January 31, 2020 by dongju.jeong Link to comment
morbid Posted January 31, 2020 Share Posted January 31, 2020 1 hour ago, dongju.jeong said: it is very helpful. but too many heavy... I see here that you're using extreme Aerosol concentration values. The effect was designed for values from 0 to 1. If you're not satisfied with the particles density — reconfigure the node in the editor, increase particles radius. Then compare which is faster for your case: intersection or collision particles culling. I explained how collision works in the previous message. To enable intersection culling just disable collision flag and enable intersection flag in particles settings. As for the moving deflector in the runtime. This sounds too complicated. I suggest optimizing your particles with intersection or collision culling. Don't forget about aerosol concentration values and particle node reconfiguration. 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
